MacBook Pro 15" Retina Mid 2014 Hard Drives
Grab a toolkit for your MacBook Pro 15" Retina Mid 2014 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
MacBook Pro 15" Retina Mid 2014 모델을 선택하십시오:
Universal Drive Adapter
Turn your current hard drive into an external drive with this part.
MacBook Pro 13" and 15" Retina (Late 2013-Mid 2014) SSD
Replace or upgrade your solid-state drive.
기기 정보
On July 29, 2014 Apple introduced a new 15" MacBook Pro with Retina display that is externally identical to the "Late 2013" model by dimensions, weight, and 2880x1800 display resolution. Internally, the Mid 2014 model has faster processors, entry level models have a single integrated graphics (IG) processor, and higher-end models offer a dual graphics (DG) processor. The Mid 2014 model has two USB 3.0 ports, an HDMI port, an SDXC card slot, a MagSafe 2 port, two Thunderbolt 2 ports, Bluetooth 4.0, and 802.11ac Wi-Fi. Like the Early 2013 and Late 2013 models the Mid 2014 does not have Ethernet or Firewire ports, although adapters are available.
The most common repairs with the 15" MacBook Pro Retina Mid 2014 laptops are replacing a dead battery, replacing a malfunctioning left or right fan, or a damaged display assembly.
The battery in a MacBook Pro 15" Retina Mid 2014 is adhered to the inside of the upper case. Our battery repair kits include the needed adhesive.
The MacBook Pro 15" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Retina Display Mid 2014 repair guides for step-by-step instructions on how to make the fix.
The MacBook Pro 15" Retina Display Mid 2014 earned a 1 out of 10 in iFixit's repairability assessment.
