MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Case Components
Grab a toolkit for your MacBook Pro 15" Unibody 2.53 GHz Mid 2009 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Trackpad
Replace a trackpad compatible with the Mid 2009 to Mid 2012 model A1286 MacBook Pro 15 inch Unibody laptop. Part #922-9035, 922-9306, 922-9749.
MacBook Pro 15" Unibody (Mid 2009) Upper Case and Trackpad
Replace an upper case, backlit keyboard, battery level indicator, and trackpad assembly compatible with the Mid 2009 model A1286 MacBook Pro 15 inch Unibody laptop.
MacBook Pro 15" Unibody (Mid 2009) Lower Case
Replace a broken or damaged lower case for your Mid 2009 MacBook Pro 15" Unibody with this part. This part includes 4 rubber feet.
MacBook Pro 15" Unibody (Mid 2009) Anti-Glare Upper Case
Replace an anti-glare upper case, backlit keyboard, and trackpad assembly compatible with the Mid 2009 model A1286 MacBook Pro 15" Unibody laptop.
Replace an upper case, backlit keyboard, and battery level indicator assembly compatible with the Mid 2009 model A1286 MacBook Pro 15 inch Unibody laptop.
MacBook Pro Unibody (Mid 2009-Mid 2012) Trackpad Mounting Screws
Replacement screws and springs for mounting the trackpad in the upper case assembly of your mid 2009 to mid 2012 13" and 15" MacBook Pro Unibody laptop.
기기 정보
The 2.53 GHz Mid 2009 version of the MacBook Pro 15" Unibody shares more in common with the MBP 13" Unibody than other MBP 15" Unibody models. The 2.53 GHz machine features a single fan and graphics chip with shared memory.
The most common repairs with 2.53 GHz Mid 2009 model MacBook Pro 15" Unibody laptops are replacing a dead battery, replacing a malfunctioning fan, and upgrading the hard drive or RAM. The MacBook Pro 15" Unibody (2.53 GHz Mid 2009) Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 8 GB of RAM.
The 2.53 GHz Mid 2009 model MacBook Pro 15" Unibody requires a P6 Pentalobe screwdriver to remove the battery. Our battery repair kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Unibody 2.53 GHz Mid 2009 repair guides for step-by-step instructions on how to make the fix.
