기기를 수리하세요
수리할 권리
상점
MacBook Pro 15" Unibody (Late 2008-Early 2009) Replacement Battery
  • MacBook Pro 15" Unibody (Late 2008-Early 2009) Replacement Battery
  • 360°
360
US$99.99
US$99.99
SKIP THE UPGRADE
Save by fixing with an all-in-one kit.
Shop iPhone Fix Kits
SKIP THE UPGRADE
제품 정보
설명
설명
This MacBook Pro 15" Unibody (Late 2008-Early 2009) replacement battery is what you need to bring your dead laptop back to life!
  • 100% factory tested.
  • Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 4940 mAh.
  • Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
  • Assembled using a high quality chipset from Texas Instruments.
Battery degradation is an inevitable part of your laptop’s lifespan, extend it with this new replacement battery compatible with Late 2008 to Early 2009 MacBook Pro 15" Unibody. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
호환성
호환성
  • MacBook Pro 15" Unibody A1286 Late 2008 to Early 2009
명세서
명세서
Part #:
661-4833
Model #:
A1281
Watt Hours:
50 Wh
Voltage:
10.8 V
Milliamp Hours:
5200 mAh
Manufacturer:
Aftermarket
호환성
MacBook Pro 15" Unibody Late 2008 & Early 2009
2.66 GHz
2.93 GHz
A1286 (EMC 2255) 2.4 GHz
A1286 (EMC 2255) 2.53 GHz
A1286 (EMC 2255) 2.8 GHz
고객 리뷰
