MacBook Pro 17" Unibody Case Components
Grab a toolkit for your MacBook Pro 17" Unibody model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
MacBook Pro 17" Unibody 모델을 선택하십시오:
MacBook Pro 17" Unibody (Early 2009-Late 2011) Trackpad
Replace a trackpad compatible with the Early 2009 to Late 2011 MacBook Pro 17 inch Unibody laptop. Part #922-9009, 922-9826.
MacBook Pro 17" Unibody (Early-Mid 2009) Lower Case
Replace a scratched or dented lower case compatible with an early or mid 2009 model MacBook Pro 17" Unibody laptop.
MacBook Pro 17" Unibody (Early-Mid 2009) Upper Case
Replace an upper case, backlit keyboard, and trackpad assembly compatible with the Early to Mid 2009 MacBook Pro 17 inch Unibody laptop. Includes the battery level indica...
MacBook Pro 17" Unibody (Mid 2010) Upper Case
Replace an upper case and backlit keyboard compatible with the Mid 2010 model A1297 MacBook Pro 17 inch Unibody laptop. Part #661-5473.
MacBook Pro 17" Unibody (Early 2011) Upper Case
Replace an upper case and backlit keyboard compatible with the Early 2011 model A1297 MacBook Pro 17 inch Unibody laptop.
MacBook Pro 17" Unibody (Late 2011) Upper Case
Replace an upper case assembly and backlit keyboard compatible with the Late 2011 model A1297 MacBook Pro 17 inch Unibody laptop.
기기 정보
The MacBook Pro 17" Unibody, announced in January of 2009 has an aluminum case like the laptops before it, however the case is machined out of a single block of aluminum. The Unibody revision also introduced some new features for Apple laptops: dual video cards (one for regular use, one for graphics intensive applications), the Mini DisplayPort (which replaced the full-size DVI display connector), and larger hard drive and RAM capacities.
The most common repairs with the Unibody model 17" MacBook Pro laptops are replacing a dead battery, replacing a malfunctioning fan, and upgrading the hard drive or RAM.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 17" Unibody repair guides for step-by-step instructions on how to make the fix.
