Macbook Pro Unibody Lower Case Screw Set
  • Macbook Pro Unibody Lower Case Screw Set / Part Only
  • Macbook Pro Unibody Lower Case Screw Set / Fix Kit
US$9.99
US$9.99
제품 재입고 메시지를 보내드리겠습니다.
제품 정보
설명
설명
Replace a stripped or missing screw securing the lower case of all 13 inch, most 15 inch, and all 17 inch Unibody model MacBook Pro laptops.
Set includes three 14 mm phillips #00 screws and seven 3 mm phillips #00 screws.
참고
Check for your model carefully in the compatibility list. The excluded Unibody models are the Late 2008 and Early 2009 15" MacBook Pro Unibody. These models have a separate battery access panel on the lower case and a different set of screws for the remaining lower case panel.
호환성
MacBook Pro 13" Unibody Early 2011
2.3 GHz
2.7 GHz
MacBook Pro 13" Unibody Late 2011
2.4 GHz
2.8 GHz
MacBook Pro 13" Unibody Mid 2009
2.26 GHz
2.53 GHz
MacBook Pro 13" Unibody Mid 2010
2.4 GHz
2.66 GHz
MacBook Pro 13" Unibody Mid 2012
2.5 GHz
2.9 GHz
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
MacBook Pro 15" Unibody Early 2011
2 GHz
2.2 GHz
2.3 GHz
MacBook Pro 15" Unibody Late 2011
2.2 GHz
2.4 GHz
2.5 GHz
MacBook Pro 15" Unibody Mid 2009
2.66 GHz
2.8 GHz
3.06 GHz
MacBook Pro 15" Unibody Mid 2010
2.4 GHz
2.53 GHz
2.66 GHz
2.8 GHz
MacBook Pro 15" Unibody Mid 2012
2.3 GHz
2.6 GHz
2.7 GHz
MacBook Pro 17" Unibody
2.2 GHz (Early 2011)
2.3 GHz (Early 2011)
2.4 GHz (Late 2011)
2.5 GHz (Late 2011)
2.53 GHz (Mid 2010)
2.66 GHz (Early 2009)
2.66 GHz (Mid 2010)
2.8 GHz (Mid 2009)
2.8 GHz (Mid 2010)
2.93 GHz (Early 2009)
3.06 GHz (Mid 2009)
기기 9개 더 보기
수리 경험담
dezineworks's Story Photo #714075
내 문제
starting to fix some old favorite MacBooks around the house
나의 수리
first iFixit project: replaced a fan in a 2006 MacBook 1,1 and a dead battery in the same 2006 MacBook. now i feel like i'm ready to learn how to replace the display. and upgrade the 350GB HD to 5400rpm or 7200rpm or 10000rpm 2TB HD or SSH . . .
내 문제
I had missing screws.
나의 수리
I ordered a new set and installed them quickly and easily. iFixit is the best.
내 조언
Always order from iFixit!
내 문제
The original battery had become swollen, and I needed to replace the battery.
나의 수리
The repair went really well, although I had removed the (original) battery previously - to prevent it from possibly leaking and ruining the computer.
내 조언
When I got the battery, I set it to the side until I had my computer set . . .
내 문제
The screws on my used Macbook Pro were really stripped, and my hard drive was failing.
나의 수리
It went great! Screws came in time, and I completed the replacement in minimal time.
내 조언
Remember to buy the appropriate screwdrivers for the repair. I used a Phillips 00 and 0. Also remember to make a Recovery USB, so . . .
내 문제
Increased RAM from 6MB to 8MB / Replaced rubber footings / Upgraded HD to 1TB SSD
나의 수리
Awesome repair job at an awesome price! Thanks Fixit.com. Just ordered another 1TB SSD for another MacBook Pro in the house.
내 조언
When ghosting/cloning your harddrive, be sure to pick a cloning software that is easy to use.
내 문제
The old battery didn't have much life left in it, but that was actually the smaller problem. The battery had gotten to the point where it had swollen so much that it was pushing up on the bottom of the track pad made clicking impossible. I had to enable some of the multi-touch features just to be ab . . .
내 문제
the back cover of my mac pro was growing old so i thought why not change it and get a new one and the screws were old so.
나의 수리
my repair want fine and okay and i was very happy with what i hard and it work very well
내 조언
please these guy have good things and they give and sent the things to you and you get them . . .
내 문제
The MBP-2012 hard drive failed. I bought (2) 1 TB SSD/HDD hybrid drives to upgrade both laptops at the same time. Incidentally I also bought RAM upgrades since I'd already have the case open.
나의 수리
The repair procedure was bumpy and required a second order for additional parts.
The RAM upgrades were the . . .
내 문제
Mac would not boot
나의 수리
Direction were perfect
내 조언
Try the 50 he cable before tossing the b
MacBook
내 문제
I've opened the back of my Macbook Pro a number of times and thought, since I was placing another Order with iFixit, that I would be proactive and also order the Lower Case Screw Set.
나의 수리
The new screws did not screw in as easily as the originals and they seemed to be softer and as a result the heads wer . . .
더 보기
