기기를 고치세요
수리할 권리
부품 & 도구
iMac Intel 20" 2.4/2.66 GHz EMC 2210 Power Supply
  • iMac Intel 20" 2.4/2.66 GHz EMC 2210 Power Supply
US$139.99
US$139.99
제품 재입고 메시지를 보내드리겠습니다.
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
Nintendo Switch 키트 쇼핑하기
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
제품 정보
설명
설명
Bring your iMac back to life!
호환성
호환성
  • 2.4 (EMC No. 2210) and 2.66 (EMC No. 2210) GHz 20" Intel iMacs
명세서
명세서
Part #:
661-4670 , 614-0438
설치 동영상
호환성
iMac Intel 20" EMC 2133 and 2210
2.4 GHz (EMC No. 2210)
2.66 GHz (EMC No. 2210)
수리 경험담
사용자 아바타
Chee Yong Koo's Story Photo #364177
내 문제
Power supply went unserviceable after 5 years of usage.
나의 수리
it definitely took an hour or so but the repair was slow, steady but smooth.
내 조언
Current guide was good enough however major improvements could have been made in the video where certain parts of "disconnecting cables /parts " of hardware made cleared . . .
사용자 아바타
내 문제
I woke up one morning to find a dead iMac (2008 20" 2.66 ghz), and then noticed the house power had gone out during the night. I like the iMac, and it synchs with my iPhone, so I decided to repair it. Also, it had 13,000 family photos going back to 2003.
나의 수리
The repair went smoothly, even with help from . . .
사용자 아바타
내 문제
My wife has a 20" Intel iMac (EMC No. 2210) which had slowed to a crawl and eventually failed to boot. I have always had PC's and wasn't shy about swapping out hard drives and performing basic hardware repairs or upgrades. I wasn't eager to go out and spend a couple grand on another Apple computer . . .
사용자 아바타
내 문제
the iphone had a broken glass display was working.The imac mod a1224 emc nr 2210 stopped working for a friend in the music aranger and musican.powersuply was the problem i found out with help fom your informative site and videos.worked with electroniks for 30 years.
나의 수리
The iphone 5s i have bougth a disp . . .
사용자 아바타
내 문제
Power supply burned out during electrical storm. Insurance declined to fix or replace as machine no longer supported by Apple. Insurance company paid me $250 which more than covered the cost of a replacement power supply from iFixit.
나의 수리
No problems, easy-peasy, with instructions from iFixit lady on yout . . .
사용자 아바타
내 문제
20" iMac EMC 2210: Overheating power supply caused a slight discoloration of the LCD screen on the corner in front of the power supply. It was also causing intermittent short term cut off of power which caused problems with the Hard Drive, That was the reason it was brought in for service.
나의 수리
Used the . . .
사용자 아바타
내 문제
We had a brownout and the iMac shut itself off. It wouldn't turn back on. I unplugged it from the wall for thirty seconds and it turned on and shut itself off again. It would not run longer than 5 minutes. So I ordered the power supply.
나의 수리
The repair went smoothly. The only trouble I had with the disass . . .
사용자 아바타
내 문제
My 20" iMac simply stopped working one evening recently while I was streaming music to my Apple TV. I did a little research and found there were diagnostic lights on the bottom. I saw light #1 (which indicates if the unit is getting power) was blinking and "guessed" the power supply had gone bad. . . .
사용자 아바타
내 문제
My desktop iMac suddenly does not turn on any more - I tried everything I can check from internet sources, from checking power cables to reseting power management, all unsuccessful. Thanks to an iFixit guide and comments, I checked the power supply unit inside iMac and appeared to be the problem, z . . .
사용자 아바타
내 문제
My iMac started acting funky. At first it just did not want to start up after a power failure. Sometimes it would just sit there and a few hours later power on. Strange very strange. Finally, it simply refused to power up. No chimes, no fan noise, no nothing. Just a door stop. What could it b . . .
더 보기
