Anti-Static Mat
  • Anti-Static Mat / 12" x 20" / New
  • Anti-Static Mat / 20" x 24" / New
  • Anti-Static Mat / 70 x 100 cm / New
Anti-Static Mat
The perfect size for phone and small electronics repair.
US$24.99
US$24.99
제품 재입고 메시지를 보내드리겠습니다.
제품 정보
설명
설명
The best protection against ESD.
  • Ground yourself and your work surface to prevent damage from electrostatic discharge (ESD).
  • Various sizes to fit any work station.
  • Learn more about how to avoid turning your beloved devices into expensive paperweights in our full post or the video below.
  • For a less-stationary alternative to this anti-static mat, see the portable anti-static mat.
제품 동영상
수리 경험담
내 문제
Problema display iPhone
나의 수리
Estuvo excelente
내 조언
No
내 문제
Broken Screen
나의 수리
Straight forward. Worked the first time.
내 조언
Use a clean white area like a anti-static mat. A head magnifier helps. The assembly requires patience as the screws are very small and hard for the average person to work with.
내 문제
I am in school getting my A+, and this Pro Tech Toolkit has everything that I need to get started.
나의 수리
New student and needed to get a toolkit. Mike Myers referred me to this company and it is great.
내 조언
Great company and great products.
내 문제
I recently installed OSX Yosemite on my Mid-2010 MacBook Pro. It had been starting to slow down since Mavericks but was slightly more noticeable again, now that I have Yosemite. So I decided it was time to invest a little to speed 'er up!
나의 수리
I bought a little more gear than I needed as i'm planning a f . . .
내 문제
The second hard drive for my MacMini Server crashed. Hopefully the OS was on the first HD so the Mac was still booting fine.
나의 수리
It was a bit challenging with a process with this many steps but every step was quite easy to do.
The hardest part was fitting the first HD in place. Like said in the g . . .
내 문제
My phone got wet after a swim in a river & a waterproof case failure. The LED flash would stay on even when I shut down the phone. Also, the phone would pretend it was always plugged into a dock, so the volume buttons would not work & I could not get any sound from videos and music.
나의 수리
It was pretty e . . .
내 문제
I'm the only IT Analyst at my site and I have to be the hands to fix everything from software, account access, to hardware support. I also have to travel to other sites to help out and this tool kit goes with me every time. My kit mainly includes the pro kit, ratchet, magnetic mat, and, etc. My f . . .
내 문제
My Galaxy S3 would intermittently (once or twice a day) lose the cell signal.
나의 수리
Being optimistic, I ordered your tools and tried to find the problem. I opened the phone and removed the first inner plate, and the shield on the SIM card fell out into my hand!
I wedged it back into its clips, put the scr . . .
내 문제
I quit trusting "Geniuses".
나의 수리
I replaced the airport card, but that didn't solve the problem.
내 조언
Easy fix if it's the actual problem.
내 문제
Track Pad was unresponsive and would not click.
나의 수리
Very simple repair. Remove lower case and battery and its just a matter of screwing the new one in.
내 조언
Be sure to check the adjustment Torx screw right next to the track pad for proper click and sensitivity. The original repair guide did not include this st . . .
더 보기
