Anti-Static Wrist Strap
  • Anti-Static Wrist Strap
$7.99
$7.99
제품 재입고 메시지를 보내드리겠습니다.
제품 정보
설명
설명
Prevent electrostatic damage.
  • Helps protect your electronics from accidental electrostatic discharge (ESD) damage during repairs.
  • Ground yourself while working on sensitive electronics to prevent static charge build-up.
  • Custom manufactured by iFixit for "American" sized wrists. Most anti-static wrist straps are made for use in manufacturing throughout Asia, and do not pass our ergonomics test, if they fit at all!
"Rapid static dissipation by a wrist strap ground is required to prevent voltage spikes. Simple movements such as lifting one foot off the floor or raising one arm from a conductive table mat may change body capacitance by as much as 10% to 30%. Uncontrolled, the capacitively created voltage may reach several hundred volts or more."
-3M Technical Brief
Specifications:
  • Band Size: .75" x 8" unstretched
  • Band Type: Elastic with adjustable buckle
  • Band Material: Polyester/stainless steel weave
  • Cord Length: Coiled, 6 Feet / 2 Meters
  • Cord Resistance: 1 M(Ohm)
수리 경험담
Jamie FC's Story Photo #927036
Jamie FC's Story Photo #927037
Jamie FC's Story Photo #927039
내 문제
My beloved phone — I've had it for years and I couldn't bear to chuck 'er in once the charger started to go. I decided to stretch myself, put my money where my mouth was, and crack open my own baby.
나의 수리
This was by far the most comprehensive repair I've done. After almost 80 screen repairs on various d . . .
MissHeather's Story Photo #593000
내 문제
The computer was overheating pretty bad and it was hard to watch video or even play a simple game without the computer shutting off.
나의 수리
It went really well. The tools made the whole process go really smoothly.
내 조언
I recommend taking your time, research the job before you start doing it, lay out all your tool . . .
내 문제
I was working at Starbucks when my friend Carlos saw me and came over to give me a hug. I knocked a whole bottle of Soylent on my keyboard. Eek.
나의 수리
It took about two hours total. I was going extra slowly because I had not worked on a Macbook before. If I should need to do it again, god forbid, it could . . .
내 문제
Mac would not boot. Initialized the hard drive, installed a new OS and replaced the battery. I did it all with the 54 bit driver set.
나의 수리
The Mac is up and working again. Quick and responsive.
내 조언
Apple wouldn't sell me a replacement battery but IFIXIT did. Thanks for the guides, parts and tools.
내 문제
MacBook not charging
나의 수리
The repair went pretty smoothly. The trickiest part was removing the keyboard ribbon cable. The instructions were not clear to show the actual location of the section that you have to flip up. With patience it wasn't too difficult to figure out. The project tray came in very . . .
내 문제
My computer was so slow I couldn't get anything done. I was running on 2GB ram.
나의 수리
Ordered a 4GB RAM chip and installed it in one of the slots, leaving the 1GB chip in the other. The installation was pretty easy. Had to do it twice because the first time it seems the computer didn't recognize it. 2nd ti . . .
내 문제
Recently, I augmented the RAM and put a new SSD hard drive into my old late 2006 core 2 duo white mac book.
I heard a guy at a computer store say that the best thing you could do was to clean out your computer, but I didn't believe him. Anyhow, I realised my computer was definitely overheating when . . .
내 문제
I am the office administrator for a small 5 staff non-profit. My boss' 2011 MBP had a bad RAM stick and an old HDD. I recommended to max out the RAM, put in a new SSD, and install Yosemite.
나의 수리
Very very very easy. I kinda wish it took longer with more steps, I was enjoying the process so much. Having th . . .
내 문제
My iPhone 4s battery was basically good for 3/4 of a day as just a phone, and about 3 hours of 4G connectivity. I could literally watch the battery tick down 1% every couple minutes. I had previously taken apart the laptop I'm typing on, cleaned it and reassembled it, so I felt fairly confident abou . . .
내 문제
thought i had a bad power supply because iMac had a problem turning on
나의 수리
the repair went well 1 hour start to finish. wish i would have read a few more forums turned out it is the button after all according to apple my entire housing needs to be replaced in order to fix this. but i read a forum an . . .
더 보기
