Calibration Thermometer in Celcius Hakko FG-100
  • Calibration Thermometer in Celcius Hakko FG-100
US$219.99
US$219.99
제품 재입고 메시지를 보내드리겠습니다.
제품 정보
설명
설명
The HAKKO FG-100 thermometer provides fast, accurate tip temperature measurements using a fine CA wire sensor (ø0.2). The FG-100 measures tip temperatures as well as solder pot temperatures (with optional temperature probe.)
Lightweight, easy-to-replace sensors provide accurate measurement of tips for verification or calibration processes. When the MAX HOLD feature is enabled, the thermometer will display the maximum temperature measured.
To preserve battery life, the auto shutoff feature turns the thermometer off when not used for three minutes. The thermometer design allows for easy measurements from right or left handed operators.
• The sensor (P/N: 191-212) has a special metal alloy coating (patent pending) that resists corrosion and oxidation.
• Sensor replacement is quick and easy
• Easy-to-read digital temperature display
Made in Japan
