기기를 고치세요
수리할 권리
부품 & 도구
ChipQuik SMD4.5 Solder Alloy
  • ChipQuik SMD4.5 Solder Alloy
US$32.99
US$32.99
제품 재입고 메시지를 보내드리겠습니다.
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
제품 정보
설명
설명
Easily remove SMD parts with Chip Quik® removal alloy
Reduce heat and reduce damage to circuit boards and SMD parts during removal. Low melting point of 58°C (136°F)
Use with SMD291 flux
(With solder iron or warm air bath)
- Apply flux to all leads.
- Melt CHIP QUIK® uniformly on all pins.
- Maintain alloy in molten state long enough to release chip.
- Lift chip from board with dental pick or vacuum pen.
CLEAN UP
- While molten, use cotton swab and flux to move excess to an unused section of board.
- While applying heat, polish each pad with a swab and flux until thoroughly clean.
- At room temperature, clean residue with alcohol pad.
- You are now ready to install the new chip.
4.5 ft of Chip Quik® material, removes up to 2700 SMD pins.
Specifications:
  • Length: 4.5 feet (8x 6.5" lengths)
  • Melting Point: 58°C (136°F)
