Desoldering Braid
  • Desoldering Braid
Desoldering Braid
US$4.99
US$4.99
제품 재입고 메시지를 보내드리겠습니다.
제품 정보
설명
설명
Desoldering Braid is great for removing excess or unwanted solder. Desoldering braid is copper with flux. Important for battery installs that require soldering or removing components from a circuit board. Works great with our Soldering Kit, but it's also a part of our Soldering Workstation.
수리 경험담
내 문제
I found a Nexus 4 in the electronics recycling bin at the recycling depot. The screen was badly cracked.
나의 수리
I followed the guide on iFixit to replace the screen. I used the iOpener to loosen the adhesive holding the screen to the frame. Swapping the screen gave me a new (looking) functioning phone!
내 조언
iFixi . . .
내 문제
A friend asked me to make an upgrade to his Nintendo GameCube. He asked for an addition of a "Xeno-GC" driver chip.
나의 수리
The GameCube case needs to be opened with a proprietary "GameBit" driver. Aside from that tool, I only needed to use two smaller Phillips drivers to disassemble every major assembly wit . . .
내 문제
The Macbook Pro was working really slow. My first thought was a failing harddrive, so i took it out, at did a test, no error. Then i thought it might be that ribbon cable. Since i live far away, i wanted to order from ifkxit because of my previous success with them. It took only 6 days to receive th . . .
내 문제
We repair many iPads/mini's and many have dented corners.
We are looking forward to using the GTool to help us with these repairs
나의 수리
So far so good
내 조언
Take your time, check and double check to make sure you have everything in it's right place.
내 문제
only 2 year old Kindle Fire . . . not charging
나의 수리
Not well - found problem, but wasn't able to fix it.
내 조언
Don't buy a Kindle Fire!
내 문제
The battery would no longer hold a charge and needed replacement.
나의 수리
I followed the directions to the letter and had no problems. Good eyesight was a must as the soldering is very detailed. Being older I had to use a lighted magnifying glass several times to see exactly what I was doing with the solde . . .
내 문제
I have been an electronics repairman for years and just began a new journey to open my own wireless repair facility and needed a few tools. I came across an article about another cellular repair shop using IFIXIT.com tool kits and when I looked into it I found the kits had exactly what I was looking . . .
내 문제
I teach an ipad repair class to a group of 8th graders. This order was just to replace some tools. We are going to give the isesamo tool a try. Our best tool so far has been a metal spudger. It has a triangular end an a curve spatula end. You sell one that looks like it but the spatula end is to du . . .
내 문제
The battery had been failing for some time, getting weaker every day at the end.
나의 수리
Not much to tell. I followed iFixit's guide for replacing the battery in a 1st gen iPod Touch. Each step went just as the Guide stated. And I succeeded!
내 조언
Just follow the Guide. This is my third use of iFixit's guides for d . . .
내 문제
I purchased the tools to use at my volunteer "job". Our group of GE retirees gifted more than 650 donated computers last year. All computers and other equipment are given to any qualified non-profit organization that requests one or many computers. Read about our group and the process for request . . .
더 보기
