Heat Gun
  • Heat Gun
  • Heat Gun
Heat Gun
Heat guns may produce residual smoke when turned off the first few times and should always be used in a well-ventilated area.
US$19.99
US$19.99
제품 재입고 메시지를 보내드리겠습니다.
제품 정보
설명
설명
Great for reflowing solder and melting adhesive.
  • The power of fire in the palm of your hand (except for the part where flames actually come out).
  • 1500W Heat Gun needed for many different repair processes.
  • Can be used to loosen adhesive holding device components in place, or to reflow solder to repair soldered connections.
High and Low Heat settings
  • Low setting reaches 570/300 degrees F/C.
  • High setting reaches 1112/600 degrees F/C.
The high setting can ignite things. It can also burn you. So watch out!
For the professional heat gunslinger, check out our pro model, the Hakko HJ5000.
Available for shipment only to the USA due to voltage requirements.
수리 경험담
Steven Rice's Story Photo #815542
Steven Rice's Story Photo #815544
내 문제
My friend dropped her phone in a parking lot.
나의 수리
I do NOT like how this phone was constructed. I was actually maimed in the process of repairing this thing. It uses these tiny little pins to hold a metal frame onto the screen assembly. It is a horrible design. I ended up getting one of those stupid litt . . .
내 문제
3 year old dropped it and shattered the screen
나의 수리
again- super easy, with the right tools. I tried with cheap picks and spudger that came with the replacement screen i got from ebay...big mistake. the picks broke with half inside and half outside the case. the cheap spudger bent and was worthless. w . . .
내 문제
Charging was intermittent and battery runs out fast - now all good with the replacement parts.
나의 수리
Doing both of these at the same time is a good idea. Good parts, good repair.
내 조언
I grabbed a BIG local business advertisement magnet from my fridge and used that up side down for all of the screws and parts. . . .
내 문제
A customer's iPhone 6 was draining battery very quickly, from 55%, it would go down to 0 in around 10 minutes. I knew this was a battery problem.
나의 수리
The screen and battery connector were very easy, but the biggest challenge has to be the iPhone 6 battery adhesive. It is so tough, and the pull tabs rip v . . .
내 문제
My Galaxy Mega 2 had a shattered screen.
나의 수리
The repair is pretty easy as long as you take your time removing the glass. It's just held together with tape so just heat it up a little around the edges and use a pick or another small tool and run it along the sides and off she comes.
내 조언
Take your time and he . . .
내 문제
RROD
나의 수리
Repair was easy enough, just followed the directions. May want to watch a video or 2 on the X clips, pretty easy to destroy the whole motherboard if you screw this part up.
내 조언
The whole process was pretty easy. To do the reflow, instead of initially heating the board with the heat gun, I put it in t . . .
내 문제
I am just starting out in the repair business, I repair all sorts of electronics, mainly the repairs are either Mobile Devices, Laptops, Computers. IFIXIT.com has a lot of the tools that are required for repairing these devices.
나의 수리
Repairs go a lot quicker with the right tools.
내 조언
Make sure you have the ri . . .
내 문제
I fixed it because it ha front and back screen broken.
나의 수리
The repair went great it's fixed.
내 조언
None i did it on my own.
내 문제
The screen shows only snow.
나의 수리
The iFixIt repair components worked fantastically! I was able to use the heat gun to melt the adhesive holding the touch pad digitizer to the iPad frame. i used: the set of picks to help separate the digitizer from the frame without damaging the plastic ring around the c . . .
내 문제
Screen is cracked.
나의 수리
Haven't do the repair yet.
내 조언
Don't drop your laptop.
더 보기
