Manta Driver Kit - 112 Bit Driver Kit
  • Manta Driver Kit - 112 Bit Driver Kit
US$59.99
US$59.99
제품 재입고 메시지를 보내드리겠습니다.
US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
제품 정보
설명
설명
The Manta Driver Kit includes iFixit's 1/4" Drive and 4 mm Drive premium aluminum screwdriver handles with magnetic bit sockets, knurled grips, and swivel tops—plus 112 precision driver bits.
This kit includes our widest assortment of bits, complete with every driver head you’ll need to tackle any repair or DIY project. It includes standard bits like Phillips and Flathead in a full range of sizes to handle everything from precision electronics repair to home DIY projects. And it wouldn’t be an iFixit bit kit if it didn’t include all the exotic bits from Pentalobes for Apple iPhone and MacBook repair to Gamebits for your vintage Nintendo consoles.
All our next-gen bit kits have been re-engineered for maximum utility. The bit kit lid is held in place with magnets to increase product lifespan (no more broken hinges or clasps) and also mounts to the back of the bit kit case to keep it out of the way while you do your work. Or, if you need help keeping your screws and parts organized, use the lid’s integrated sorting tray. And our 4 mm bits have been redesigned with a longer neck for a deeper and more precise reach.
Toolkit Includes
  • Easy-to-Open Magnetized Case
  • Lid with Built-in Sorting Tray
  • 4 mm Aluminum Bit Driver
  • 1/4" Aluminum Bit Driver
  • 4 mm Screwdriver Bits
    • Phillips - 000, 00, 0
    • Flathead - 1, 1.5, 2, 2.5, 3, 3.5 mm
    • Torx - T2, T3, T4, T5
    • Torx Security - TR6, TR7, TR8
    • Pentalobe - P2, P5, P6
    • JIS - 000, 00, 0, 1
    • Hex - 0.7, 0.9, 1.3, 1.5 mm
    • Hex Security - 2, 2.5, 3, 3.5 mm
    • Tri-point - Y000, Y00, Y0, Y1
    • Nut driver - 2.5, 3, 3.5, 4, 4.5, 5, 5.5 mm
    • Gamebit - 3.8, 4.5 mm
    • Spanner - 4, 6
    • Triangle - 2, 2.2, 2.6, 3 mm
    • Oval Bit
    • iPhone Standoff Bit
    • Sim Eject Bit
    • Magnetic Pickup Bit
  • 1/4" Screwdriver Bits
    • Phillips - 1, 2, 3
    • Flathead - 4, 6, 7, 8 mm
    • Hex Security - 4, 5, 6, 7, 8 mm
    • Hex Security SAE - 1/8, 9/64, 5/32, 3/16, 7/32, 1/4
    • Pozidriv - PZ0, PZ1, PZ2, PZ3
    • Torq-set - 6, 8, 10
    • Spanner - 8, 10, 12
    • Square - 0, 1, 2, 3
    • Spline - M5, M6, M8
    • Torx Security - TR9, TR10, TR15, TR20, TR25, TR27, TR30, TR35, TR40
    • Tri-wing 1, 2, 3, 4
    • Clutch 1, 2, 3
    • Schrader Valve
    • Hook Drive
    • 1/4" to 4 mm Adapter
    • 1/4" Driver to 1/4" Socket
    • 1/4" Driver to 3/8" Socket
    • 1/4" Socket to 1/4" Driver
고객 리뷰
