Professional 56 Driver Set
  • Professional 56 Driver Set
비매품
비매품
비매품
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
제품 정보
설명
설명
The end-all, totally comprehensive screwdriver set.
  • Each driver is ESD safe and built with a solid metal shaft, ergonomic plastic handle, and rotating top for easy use.
  • A complete set of fixed drivers for common screw sizes and interchangeable bits for the more obscure screw heads.
  • Packaged in an attractive wooden case with soft molded interior.
Set includes:
  • Slotted .025", .040", .055", .070", .080", .100", .125", .141", .156"
  • Phillips #000, #00, #0, #1
  • JIS-type S #0, #1
  • Hex .028", .035", .050"/#4, .062"/#6, .078"/#8, .093"
  • Metric Hex 0.7mm, 0.9mm, 1.3mm, 1.5mm, 2.0mm, 2.5mm
  • Torx® T-1, T-2, T-3, T-4, T-5, T-15, TP-8, TP-10
  • Nut Driver 5/64", 3/32", 7/64", 1/8", 5/32"
  • Metric Nut Driver 2.0mm, 2.5mm, 3.0mm, 3.5mm, 4.0mm
고객님들이 함께 구매함
