iFixit Opening Picks (Set of 6)
  • iFixit Opening Picks (Set of 6) / New
  • 360°
360
US$4.99
US$4.99
제품 재입고 메시지를 보내드리겠습니다.
제품 정보
설명
설명
Pick your way to repair!
  • 6 very thin opening picks
  • Can be used for prying, sliding, separating, and air guitaring.
  • These picks are especially useful for prying open iPads and other glue-laden devices.
수리 경험담
Scott Cassio's Story Photo #885867
내 문제
Cracked front panel assembly
나의 수리
The repair is pretty straight forward until the conclusion which states, 'But first ensure to place a narrow piece of tape over the copper/silver at the bottom of the digitizer to the left and right of the home button.'
Since there was no tape in those areas when I took . . .
내 문제
Old battery couldn't hold a charge for long.
나의 수리
Your tools made getting into the case easy. The only problem was getting the old battery out... Too much original glue!
The supplied tools made the job much easier.
내 조언
Don't try to open the case with your fingernails!
내 문제
Spider web screen
나의 수리
Repair went very well instructions were plain enough was a little nervous of crushing a connector after the first one was in it was smooth sailing about an hour to do
내 조언
Go slow take your time and follow instrutions
내 문제
Accidentally dropped my phone right on the back.
나의 수리
With a heat gun on low the glue softened up very easily. Needed something sharper and thinner to get under the glass but once I did it peeled off easily. Removed all the old glue with a knife to hopefully retail some water resistance.
내 조언
Use the heatgun . . .
내 문제
Screen was badly cracked after bing dropped on corner of iPad.
나의 수리
Repair went smoothly. No major issues but needed another tool to make it really work.
내 조언
Need to stay patient as it's tedious work getting the screen off. After that it's pretty easy. The plastic tool to pry open the screen from the edge isn' . . .
내 문제
My wife's phone. She cracked her LCD screen
나의 수리
The "Ifixit" video manual was to the point and quite accurate except a couple of things. On this particular phone the original adhesive refused to let go after heating the chassis several times. The iSclack was not strong enough to lift the rear cover loos . . .
내 문제
My power switch was stuck. I bought a spare part off eBay.
나의 수리
You guys rated the fixability a "1" and I completely agree. What a pain. I was able to get the switch replaced and the unit works except that when I was using the picks I pushed one in too far and it broke the digitizer membrane on the top-le . . .
내 문제
Cracked Screen
나의 수리
Great!
내 조언
Becareful where you order your screens. I had to do this twice!!
내 문제
Kindle would not charge unless you did the wire dance ( moved it all over) until you find the spot that if you're lucky will charge after you sit it down . Got to the point that I had to do it without moving the Kindle.
나의 수리
Very well, you just have to pay attention to details.
내 조언
Have a clean surface and all . . .
내 문제
iPad 4th Gen WiFi with a broken front glass.
나의 수리
The instructions were great except that for some reason, they assumed that I would be replacing an intact glass panel. Mine was broken in 4 lines, and every time I got to another break, it would shatter down to powdered glass and glue (Yes I know it is 3M . . .
더 보기
