iSesamo Opening Tool
  • iSesamo Opening Tool
  • 360°
360
US$9.99
US$9.99
제품 재입고 메시지를 보내드리겠습니다.
제품 정보
설명
설명
Crafted for one purpose
A thin sheet of springy steel, designed to slide easily between panels and into microscopic cracks. An expertly curved tip, perfected to get the right angle on electronic casing clips. And with a no-slip grip, this tool is much more effective and reliable than other case opening methods.
  • This tough tool nimbly pops open modern small electronics casings.
  • Springy steel blade features a smart tip design and a handle with a great no-slip grip.
Be sure to exercise caution when using this tool. With its great strength comes the potential to scratch or otherwise damage components that might be better served with plastic tools such as a spudger or plastic opening tool.
제품 동영상
수리 경험담
tomm's Story Photo #1334078
내 문제
iPod Photo purchased when first released. Replaced battery using iFixit parts, tools, and guide six or seven years ago. That battery started quitting when indicating about 1/2 charged. Decided time to fix it again.
나의 수리
I couldn't get the case open. Trying from the right side as indicated in the guide . . .
내 문제
Yes I’m learning how to repair iPhones with these tools. Thank you!
나의 수리
It went good
내 조언
I fixed an iPhone 5s
내 문제
My phone got dropped at the airport and cracked the upper left corner of just the glass, still worked fine, but I researched changing the glass only and most of the feedback indicated that you'd damage the digitizer in the process so I opted to order the screen and digitizer assembly. My wife had d . . .
내 문제
Reemplace el conector de carga, la guía me sirvió mucho :)
나의 수리
Fue un poco complicada pero al fin y al cabo logré la reparación
내 조언
Usen una luz blanca para prestar atención al lcd, este se podría quemar por el calor
내 문제
An older iPhone 4 with a cracked screen was going to waist in my dresser. I found myself reading for it when my new fone was on the charger but e screen was a mess.
나의 수리
The repair wint great. No issues not if is a pleasure to use for late nite browsing and email. I forgot hi good the smal screen actu . . .
내 문제
My iphone 6 screen was broken and i bought from another seller and it appeared to be of poor quality so i decided to buy from ifixit and it went all well
나의 수리
Smooth. I had the islack which works like a charm. Easy to open the iphone
내 조언
Buy from reliable sources like ifixit
내 문제
My daughter cracked her iPhone 5S screen while at college after only having the phone for about 5 months. I decided I would fix it myself while she was home for Christmas break. I also decided that while I was at it, I would fix her older iPhone 4S cracked screen and sell that phone to help pay fo . . .
내 문제
I was tasked with replacing the battery in 14 Ipad Gen 1's - That seemed easy enough, since I'd been repairing PC for Years.
나의 수리
The Repair started out ok I received my tools, and went right to work, using the iSesamo Tool I opened the first ipad pretty easy, The only issue I have with the iSesamo Tool i . . .
내 문제
The charging port on my iPhone 5 was shorted.
나의 수리
After looking at the repair guide for a while, I managed to open and fix the iPone for the first time in about an hour.
내 조언
Pay attention to how you remove the loudspeaker. That almost tripped me up while reinstalling.
내 문제
Wacko iPad decided to fly out of my hand. All went well for about 2 seconds, then it fell down a flight of concrete and steel stairs.
나의 수리
All went as described. My only problem was the chassis was somewhat deformed at the corners, causing some difficulty fitting the bezel. Turned out okay though.
내 조언
Dry fit . . .
더 보기
