내 문제
The power button on my wife's 4s broke - the common problem they have with the flex circuit.
나의 수리
I worked step by step, took my time and at the end the phone repair was successful.
내 조언
A plastic spuder tool is too fragile to remove the battery. Use the heavier duty prying tool to release it from the frame. The clip that holds the proximity sensor can be tough to get out - be patient and work it carefully. Make sure you have a tool kit with a good pair of work tweezers. The ones I have worked but were a bit cumbersome to use.
댓글 0개
