내 문제
My airport card stopped working at random. Often when i moved the computer. Sometimes it worked to shut off the computer, open and close the lid a few times and start it again to get it working so i suspected a glitch somewhere and the cable was cheap so i thoughti might as well try changing it.
나의 수리
Very easy install, just unscrew the bottom cover and pop out the old cable and in with the new one.
내 조언
If your airport card is failing this might be the cause. The fix is cheap enough to do even if it might not solve the problem.
댓글 0개
