내 문제
My laptop didn't just suddenly stop charging. No, it would charge if I had the cable in JUST the right way... you know how it goes. After I bought a new cable and found the same problem, I knew it had to be the port. Angst and despair set in.
나의 수리
It was a long and scary process. I've replaced the logic board on an iBook before, but it required less work. I found and cleaned out about three cats' worth of fur inside while I was at it, and thought for sure I was going to destroy the microphone detaching it.
내 조언
Screw down the Magsafe port slightly before putting the motherboard back in. It popped up above the logic board and I had to unscrew the logic board in order to wiggle it back down into place. Get about a dozen little yogurt cups, Tupperwares, or other small containers and keep each step's screws separate.
댓글 0개
