내 문제
Display was being pushed out (for whatever reason) and ultimately popped out, breaking the two little screw holes in the process.
나의 수리
Fast, if with a bit of fiddling with the tiny screws. The display ribbon cables are more resilient than they look, apparently.
내 조언
The shorter screw near the battery is attached to a lifter pole, not the board itself - take care to not to unscrew the pole in the process, or re-assemble everything in order.
댓글 0개
