내 문제
A customer's iPhone 6 was draining battery very quickly, from 55%, it would go down to 0 in around 10 minutes. I knew this was a battery problem.
나의 수리
The screen and battery connector were very easy, but the biggest challenge has to be the iPhone 6 battery adhesive. It is so tough, and the pull tabs rip very easily. I got the first one off (for the first time in my life) and the second one snagged and ripped in half. I had to use a heat gun to get it out, which took around 10 minutes. Reassembly was very easy
내 조언
Because the first part is very easy, don't be tricked by the adhesive pull tabs, you have to take your time with them, and if they snap/rip, you will need a heat gun, hairdryer or iOpener to help you. Replacement adhesive isn't required, I just used double-sided tape, which makes it easier to reposition.
댓글 0개
