내 문제
Old battery
나의 수리
It went well enough, although it wasn't a snap. Disassembly went smoothly, although an iClack would have helped. Removing the old adhesive was difficult. Both adhesive strips broke quickly after they were gently lifted. A hair dryer made the adhesive pliable enough that a plastic card could be used to slowly, very slowly, lift the old battery out. I found reattaching the cables also difficult. They have to be perfectly aligned. No tool convinced me they were inserted except for my finger. The new battery is working well.
내 조언
Heat the old adhesive strips BEFORE attempting to pull them out; don't wait for them to break. And put a zip tie around the phone to prevent inadvertently damaging the home button cable. I made a movement limiter with a clothes pin and some wire, but later read someone's else's suggestion of the zip tie. It is a much better solution.
댓글 0개
