내 문제
I cracked the lens cover on some rocks while I was fishing. The phone was in my pocket. I dragged my feet in fixing it and ended up needing to replace the rear facing camera as well.
나의 수리
Very smooth. Instructions were clear and accurate.
내 조언
The adhesive that comes stock is pretty good. Once you get a sense of the amount of resistance it gives, you can move forward confidently. The bezel for instance was fastened on pretty tightly with the tape and I was nervous about the amount of force required to move it. Just applied a little heat to the area and it started to give some. Then I knew it was just tape.
댓글 0개
