내 문제
Screen had one horizontal crack. I can see why it'd be a bit more difficult if it were shattered but taped up it shouldn't be that much harder.
나의 수리
Perfect, looks like new for a lot less cost. Working with the small screws requires patience, get organized before you start! I put double sided tape on a sheet of paper and set the screws on the tape. I labeled each piece of tape and organized the screws as I removed them. I used a pillow case as a working surface.
If you drop one of those small screws I'd be easy to loose.
I replaced the battery as well as the front screen. Slow steady pull on the adhesive strips worked as advertised, no breaks. Take your time and do not rush.
내 조언
Patience and a magnifying loop were mandatory for me.
댓글 0개
