내 문제
Needed battery for my Honda key fob
나의 수리
This key fob requires the removal of an extremely small phillips screw to separate the key fob to access the battery; I had a couple of small screw drivers on hand and proceded with them but could not break the screw lose. I started rounding the phillip + out and thought oh s**t I’ve done it now. So I found your Webb site and found your fix for this task along with your wonderful German #0 Phillips screwdriver. I ordered and received the screwdriver then rested the key on a solid surface in order to apply sufficient pressure on the screw as I turned it. It worked!!! I could not have done it without your wonderful screwdriver!
내 조언
Don’t round out the + from the head of a Phillips screw; use a good screwdriver
댓글 0개
