내 문제
Phone was stepped on and shattered screen. Display did not work. Still received phone calls and charging/notifications light still worked.
나의 수리
That adhesive is no joke. Paint stayed stuck to the adhesive from the back panel. So now you can see through the back panel after assembly. The new adhesive for the back panel came stuck to the green plastic backwards. Made it a bit more difficult to stick to the phone.
내 조언
Heat is the trick. The heat pack that came with the kit worked really well. Did have to use hair dryer as well.
댓글 0개
