주요 콘텐츠로 건너뛰기
« 모든 스토리로 돌아가기
"Simpler" battery replacement
Richard Stanford -
MacBook Pro 15" Retina Display Mid 2012
MacBook Pro 15" Retina Display Mid 2012 Battery Replacement
45 분
Moderate
내 문제
My battery was throwing warnings and would last maybe 60 minutes on a good day.
나의 수리
The repair went well. I only used the tools that came with the kit and they were great.
내 조언
Like many others, I chose not to disassemble the entire laptop. I removed the case, unplugged the battery, tilted it up, and ran the adhesive remover down under the batteries several times before prying them out. It was much simpler. I didn't have much luck using string, but the prying tools worked just fine.
I did have to spend close on 30 minutes cleaning off the old adhesive. Mine was especially sticky, even when compared to others I saw in videos.
I also accidentally removed the cover for the trackpad (the adhesive remover did its work there as well). I don't see this being covered in the official guide, but I'd imagine that the same problem would exist.
MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery 이미지
$89.99
« 모든 스토리로 돌아가기
댓글 0개
댓글 쓰기
