주요 콘텐츠로 건너뛰기
« 모든 스토리로 돌아가기
Macbook fan replacement
Mike Noll -
MacBook Pro 15" Retina Display Mid 2015
MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement
45 분
Moderate
내 문제
Computer wasn't cooling, fans made clicking noise.
나의 수리
Flawlessly. The repair guide is very well laid out. Follow the steps, be patient, and the process will work.
내 조언
1.) If you're going to the trouble of replacing fan(s), check out the battery while you're at it. Replacing that as well isn't that much more work.
2.) I bought the ifixit toolkit (very well stocked!) meaning I had multiple spudgers. For the connectors that pop straight up (like the IO cable running across the right fan), using two spudgers simultaneously allows straight up action instead of a bit of shear from one-sided prying.
Spudger Retail 3 Pack 이미지
$8.95
« 모든 스토리로 돌아가기
댓글 0개
댓글 쓰기
