주요 콘텐츠로 건너뛰기
« 모든 스토리로 돌아가기
The Case of the Shy Power Supply: A Resurrection Story
siecon -
스토리 이미지
내 문제
So, my buddy brings over his beloved high-end gaming PC. "It's dead, Jim," he says. No power, no lights, no dramatic smoke, just... silence. But here's the clue: if you left it unplugged for a while, it would sometimes power on for a few seconds before dying again. It was like a shy creature that needed a long rest before mustering the energy for a brief "hello."
This pointed directly to the heart of the machine: the Switch-Mode Power Supply (SMPS) .https://sieconxk.com/ .motherboard. It wasn't completely dead; it was protecting itself. The problem was likely in the primary side, probably a component failing under load.
나의 수리
UNPLUG EVERYTHING. I can't stress this enough. Those big capacitors can hold a lethal charge for a long time. I discharged them properly using a resistor. Safety first, always!I opened up the PSU and gave the board a good look. I was looking for the usual suspects: bulging capacitors, burnt resistors, or any signs of overheating. Bingo! Two little guys near the primary side were looking a bit pregnant. These were the startup capacitors – crucial for providing the initial jolt to the main switching IC.I used a multimeter to check the suspect capacitors. Their capacitance was way below their rated value. They had grown weak and couldn't hold a charge properly, which explained why the PSU couldn't start reliably.I carefully desoldered the two bulging capacitors. I then soldered in two new, high-quality ones with the same (or slightly higher) voltage and capacitance ratings. No fancy tricks, just clean soldering work.I reassembled the unit, plugged it in from a safe distance (just kidding... mostly), and hit the power button. The lights blazed to life, and the fan spun up with a healthy whirr. Success!The patient made a full recovery! The PC has been running perfectly for months now, with no more shy behavior. It's now a brave, always-ready gaming beast.
내 조언
Capacitors are the Usual Culprits: In older electronics, failing electrolytic capacitors are the cause of over 80% of failures. Always check them first.
Quality Matters: Don't just replace a bad cap with an equally cheap one. Spend a little extra on reputable brands (like Nichicon, Panasonic) for a longer-lasting repair.
If you see a fuse blown, DON'T just replace it. A blown fuse is a symptom. There's almost always a short circuit elsewhere that caused it to blow. Find and fix the root cause first.
« 모든 스토리로 돌아가기
댓글 2개
Yes, I have found the capacitors culprit in many cases and a suitable replacement solves the problem.
My experience is that high value capacitors fail more often than the lower ones in picofarad ranges!
Umchbh - 답글 공유
Absolutely,Once you swap in the right ones, the machine just comes back to life. Do you guys also suspect the capacitors first when fixing equipment?
siecon - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 17
전체 시간: 363
