내 문제
Dropped iPod classic 7G had cracked screen. Decided to upgrade while fixing, so I replaced the LCD and swapped in a Toshiba 240gb drive. Thicker drive necessitated using a thicker back, so I had to replace the back too.
나의 수리
Piece of cake. As usual, the hardest part was getting the case open. Was done in 20 minutes.
내 조언
Unless your screen is already cracked, keep away from the screen as much as possible when opening the case. Work in the middle of the longer-sides first...then get the bottom going. Go SLOWLY!
댓글 0개
