« 모든 스토리로 돌아가기
Broken pwr button - rplcd pwr button, volume buttons, mute switch, hdphone jack
mmbt -
iPhone 3GS
iPhone 3GS Headphone Jack Replacement
Difficult
내 문제
Would not power on or off using power button
나의 수리
Following directions, repair went great. Be prepared for it to take at least two hours, have a good lighting source and a safe place to store very small screws. Cable itself is somewhat difficult to work with.
내 조언
The hardest part is the mute switch. There is a small pad that needs to be positioned correctly on the external plastic switch body and the mute switch needs to fit into a small opening in the external plastic switch body. I could never get it right until I used a tiny bit of glue from the battery to hold the pad in place and to hold the switch in the correctly aligned position. After that, no problem.
iPhone 3G/3GS Headphone Jack Assembly 이미지
$14.99
« 모든 스토리로 돌아가기
댓글 0개
댓글 쓰기
