내 문제
The Mic went dead and we figured trying the repair/replacement was a no loose situation.
나의 수리
We ran into a fit problem with the dock connector itself. Although the old part slipped in and out the new part was a little off - enough that the internal mounting screw holes were not aligned with the part. I cleaned a bit of flashing from the connector and using a small jewelers file opened the holes on the part slightly. From that point all was good and well worth the effort!
내 조언
Don't forget to remove the protective film on the adhesive - got to use that stickum!
댓글 0개
