해당 분해도는 작업 중 입니다 – 최신 변경 사항을 보려면 주기적으로 다시 로드 하십시오!
해당 분해도에 사용된 도구
  1. There are three blue LEDs to show you the power in the battery. There is also a handy LED to see what you are doing in the dark.
    • There are three blue LEDs to show you the power in the battery.
    • There is also a handy LED to see what you are doing in the dark.
  2. The bottom of the device. It's time for some prying. Take out the rubber plugs at the bottom of the device. Remove the screws which are underneath the plugs.
    • The bottom of the device.
    • It's time for some prying. Take out the rubber plugs at the bottom of the device.
    • Remove the screws which are underneath the plugs.
  3. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. use a flathead screwdriver or a spudger to pry open the device. Don't pry at the front of the device - there are a few hooks and you do not want to break them.
    • use a flathead screwdriver or a spudger to pry open the device.
    • Don't pry at the front of the device - there are a few hooks and you do not want to break them.
  5. A first glance at the inside: a big battery and the logic board.
    • A first glance at the inside: a big battery and the logic board.
    • There is a 1800 mAh battery in it.
    • There are two screws in the logic board, the battery is glued to the casing.
  6. The other side of the electronics. And the logic board.
    • The other side of the electronics.
    • And the logic board.
  7. And there it is: the A-Solar PowerBank AL-200 torn down.
    • And there it is: the A-Solar PowerBank AL-200 torn down.
    • It was easy to do.
storm
회원 가입일: 2012년 07월 07일
506 평판
안내서 2개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 19
전체 시간: 3,350
