주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. A.C.Ryan PlayOn!HD 수리는 저희 서비스 설명서를 사용하십시오.
  1. A.C.Ryan PlayOn!HD Teardown, A.C.Ryan PlayOn!HD Teardown: 1 단계, 이미지 1/2 A.C.Ryan PlayOn!HD Teardown, A.C.Ryan PlayOn!HD Teardown: 1 단계, 이미지 2/2
    • The ACRyan PlayOn HD with remote control.
  2. A.C.Ryan PlayOn!HD Teardown: 2 단계, 이미지 1/2 A.C.Ryan PlayOn!HD Teardown: 2 단계, 이미지 2/2
    • The rear panel with the necessary connectors.
  3. A.C.Ryan PlayOn!HD Teardown: 3 단계, 이미지 1/2 A.C.Ryan PlayOn!HD Teardown: 3 단계, 이미지 2/2
    • The location of the 2.5 HD is at the bottom of the case.
  4. A.C.Ryan PlayOn!HD Teardown: 4 단계, 이미지 1/3 A.C.Ryan PlayOn!HD Teardown: 4 단계, 이미지 2/3 A.C.Ryan PlayOn!HD Teardown: 4 단계, 이미지 3/3
    • The small motherboard with the USB and IR receiver PCB.
Vincent Tay
회원 가입일: 01/14/14
101 평판
안내서 1개 작성함
댓글 4개
Hi,
I have a somewhat different problem my remote broke and before I buy a new one I want to try fixing mine there are two components missing which I could easily replace but I don't know the ratings or model numbers of the components. So if anyone could send me pictures of the components that would be awesome.
mpinnie - 답글
Have you fix it? Or you had threw it away?
Bee B - 답글
Hi
the ac Ryan is not being recognised by my laptop through USB Connection.
Is there any remedy?
Cyril Kevin - 답글
Hi! Where can I buy the remote control of AC Ryan
Roberto Albino - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 17
전체 시간: 3,409
