주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. ALCATEL 5015A Pixi 3 (5) 3G 수리는 자사의 서비스 설명서를 사용하세요.
  1. ALCATEL 5015A Pixi 3 (5) 3G Teardown, Remove the inside panel - screws: 1 단계, 이미지 2개 중 1개 ALCATEL 5015A Pixi 3 (5) 3G Teardown, Remove the inside panel - screws: 1 단계, 이미지 2개 중 2개
    • Once you have the back removed and the battery set aside, you have 4 (long screws) at the corners, and 4 (smaller) screws in the middle. Set these aside in a safe place. (I used the back of the phone itself)
  2. ALCATEL 5015A Pixi 3 (5) 3G Teardown, Separating the rear frame.: 2 단계, 이미지 3개 중 1개 ALCATEL 5015A Pixi 3 (5) 3G Teardown, Separating the rear frame.: 2 단계, 이미지 3개 중 2개 ALCATEL 5015A Pixi 3 (5) 3G Teardown, Separating the rear frame.: 2 단계, 이미지 3개 중 3개
    • Find a small crevice along the outside and carefully insert your spudger, small screw driver or guitar pick tool inside and slide it along the length of the side to seperate the front assembly from the rear.
    • Carefully work the opposite side as well, you will need to duplicate while being mindful of the circuit board.
  3. ALCATEL 5015A Pixi 3 (5) 3G Teardown: 3 단계, 이미지 1개 중 1개
    • Take care not to damage the ribbon cable connectors (red arrows) coming from the front display assembly attempting to lift the circuit board from the display.
    • The guitar pick tool (orange arrows) should slide easily under the circuit board except for where the cables might still be connected.
  4. ALCATEL 5015A Pixi 3 (5) 3G Teardown, Camera & Cables: 4 단계, 이미지 2개 중 1개 ALCATEL 5015A Pixi 3 (5) 3G Teardown, Camera & Cables: 4 단계, 이미지 2개 중 2개
    • Carefully remove the rear facing camera (pink box) and lift the speaker upwards (blue box - do not try to disconnect). The speaker is held in place by the magnet on the backside. You may need flat edge under the side to separate it from the plate of metal.
    • Carefully seperate the ribbon attachment from the top (red box) to remove the front facing camera (adhered to the front) with a small piece of adhesion.
  5. ALCATEL 5015A Pixi 3 (5) 3G Teardown, Cables continued...: 5 단계, 이미지 2개 중 1개 ALCATEL 5015A Pixi 3 (5) 3G Teardown, Cables continued...: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Carefully lift (with tweezers or small pliers) the connection indicated by the yellow box(s)
    • Next lift, with tweezers or spudger (carefully) the connection indicated by the blue box marker.
    • You will need a flat surface to lift carefully the clip which holds the connector indicated by the green box. You can then use a pair of tweezers (or your fingernails?) to slide the connector to the side.
  6. ALCATEL 5015A Pixi 3 (5) 3G Teardown, Separate the circuit board: 6 단계, 이미지 3개 중 1개 ALCATEL 5015A Pixi 3 (5) 3G Teardown, Separate the circuit board: 6 단계, 이미지 3개 중 2개 ALCATEL 5015A Pixi 3 (5) 3G Teardown, Separate the circuit board: 6 단계, 이미지 3개 중 3개
    • The circuit board should separate with little or no effort.
    • The orange box marker shows sighs of water damage. This phone had been dropped in a puddle.
작성자
4다른 기여자 명과 함께
Thomas Keats
회원 가입일: 02/08/16
343 평판
안내서 1개를 작성함
Rainbow Computers Rainbow Computers 회원
Business
1 회원
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 28
전체 시간: 3,512
