주요 콘텐츠로 건너뛰기
해당 분해도는 수리 안내서가 아닙니다. ASUS ZenPad S8 수리는 자사의 서비스 설명서를 사용하세요.
  1. ASUS ZenPad S8 Teardown, ASUS ZenPad S8 Teardown: 1 단계, 이미지 2개 중 1개 ASUS ZenPad S8 Teardown, ASUS ZenPad S8 Teardown: 1 단계, 이미지 2개 중 2개
    • ASUS ZenPad S8 outside
  2. ASUS ZenPad S8 Teardown: 2 단계, 이미지 1개 중 1개
    • The back case didn't use any screw or glue. The back case only use tenons to stick with front case. It's not hard to take apart.
  3. ASUS ZenPad S8 Teardown: 3 단계, 이미지 3개 중 1개 ASUS ZenPad S8 Teardown: 3 단계, 이미지 3개 중 2개 ASUS ZenPad S8 Teardown: 3 단계, 이미지 3개 중 3개
    • There are three big parts in tablet-- upside circuit board, battery and downside circuit board. Base on my experience, upside circuit board has more important IC chips than downside board.
  4. ASUS ZenPad S8 Teardown: 4 단계, 이미지 3개 중 1개 ASUS ZenPad S8 Teardown: 4 단계, 이미지 3개 중 2개 ASUS ZenPad S8 Teardown: 4 단계, 이미지 3개 중 3개
    • Let's closer look at the upside circuit board. We found 4 important IC chips.
    • Hynix 4GB LPDDR3 DRAM.
    • Intel Atom Z3580.
    • Kingston eMMC 32GB NAND Flash
    • Pixelworks PX8458WM. This is the independent high-end TV level video processor I'm looking for!!!
  5. ASUS ZenPad S8 Teardown: 5 단계, 이미지 3개 중 1개 ASUS ZenPad S8 Teardown: 5 단계, 이미지 3개 중 2개 ASUS ZenPad S8 Teardown: 5 단계, 이미지 3개 중 3개
    • Let's measure the size of Pixelworks IC. It's about 5mm x 5mm (0.2inch x 0.2 inch)
    • From Pixelworks CEO comment, we know ASUS ZenPad S8 use IRIS1 chip. Although IRIS1 chip also target on smartphone market, we didn't find any smartphone use IRIS1 chip yet.
    • When I ask ASUS tablet PM about the possibility of IRIS1 on smartphone, he imply the power consumption level of IRIS1 may not reach smartphone requirement. It will be more reasonable to see IRIS1 on tablet or laptop.
작성자
1다른 기여자 명과 함께
Ken
회원 가입일: 11/20/13
273 평판
안내서 1개를 작성함
댓글 15개
Step 4 , Green color highlighted part cannot be Intel atom cpu, it should be PMU
Buddhika Mahesh - 답글
It's hated too tell from your guide, but is it possible too replace the battery?
Geoffrey Paxson - 답글
Hi! I have a cracked screen and am looking on eBay for replacements. Most sellers only have one part, but a couple sellers have two digitizer/screen variants with the difference being the width of the connector cable. Does anyone know how to determine if there actually are two variants and if so, how to know which to order? Thanks in advance.
Zack Westlie - 답글
I have the Asus S 8 and it too has a cracked screen. I found this video on youtube.com where a guy replaces the glass screen on an Asus Transformer. He does mention two "ribbons" inside with numbers on them and says you should look at that to order the right screen, Right now, I'm trying to find a seller with the right glass. The digitizer is okay, it is only the glass which is cracked, it still works.
https://www.youtube.com/watch?v=kmN_pDAF... is the video showing his repair.
Regards,
chita.jing@gmail.com
chita jing -
There are 2 sizes. 28mm and 26mm. If the number on the ribbon ends in 05 it's 28mm. If it ends in 06 it's 26mm. Hope this helps. It did when I fixed mine. Now if I can find a good rear housing cover for it I'll be set. Good luck.
Brett Turner -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 24,331
