주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. AWEI BT Earbuds 수리는 저희 서비스 설명서를 사용하십시오.
  1. AWEI BT Earbuds & Receiver Teardown, Earbud Dissasembly: 1 단계, 이미지 1/2 AWEI BT Earbuds & Receiver Teardown, Earbud Dissasembly: 1 단계, 이미지 2/2
    • Remove Earbud Cushion
  2. AWEI BT Earbuds & Receiver Teardown, Secure Earbud for Separation: 2 단계, 이미지 1/1
    • Secure Earbud End (eg:Vice)
  3. AWEI BT Earbuds & Receiver Teardown, Separate Earbud Sections: 3 단계, 이미지 1/2 AWEI BT Earbuds & Receiver Teardown, Separate Earbud Sections: 3 단계, 이미지 2/2
    • Using Pliers Gently Twist & Pry Away Sections, Do Not Twist more than 3-4mm
  4. AWEI BT Earbuds & Receiver Teardown, Inspect Separated Earbud Internal Wiring: 4 단계, 이미지 1/1
    • Inspect Earbud Wiring
  5. AWEI BT Earbuds & Receiver Teardown, Separate Receiver Housing: 5 단계, 이미지 1/3 AWEI BT Earbuds & Receiver Teardown, Separate Receiver Housing: 5 단계, 이미지 2/3 AWEI BT Earbuds & Receiver Teardown, Separate Receiver Housing: 5 단계, 이미지 3/3
    • Using a small pick or pry tool, separate Receiver Housing. Each side is secured by 3 small fragile tabs. Use the space near the micro USB opening & carefully pry to separate the 3 tabs on the opposite side.
  6. AWEI BT Earbuds & Receiver Teardown, Inspect Receiver Internal Wiring: 6 단계, 이미지 1/3 AWEI BT Earbuds & Receiver Teardown, Inspect Receiver Internal Wiring: 6 단계, 이미지 2/3 AWEI BT Earbuds & Receiver Teardown, Inspect Receiver Internal Wiring: 6 단계, 이미지 3/3
    • Carefully Separate the PCB to inspect the headphone's left & right earbud wiring. Cleaned up any broken connections by de-soldering, re-tinning wires & re-soldering to the PCB. Each side is labeled L + L - and R + R - the colored wire is positive and the bare wire is negative.
    • Assemble Unit in reverse order.
fugitiveALiEN
회원 가입일: 02/28/13
188 평판
안내서 1개 작성함
My Techno Guy My Techno Guy 회원
Business
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 14
전체 시간: 1,569
