주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Acer Liquid E1 수리는 저희 서비스 설명서를 사용하십시오.
  1. Acer Liquid E1 Teardown, Acer Liquid E1 Teardown: 1 단계, 이미지 1/1
    • Remove the plastic back and the exposed battery.
    • Do not forget to remove sim- and SD-cards
    • Use a torx t5 to unscrew all screws. This will be the first and last time you'll use a screwdriver with this device.
  2. Acer Liquid E1 Teardown: 2 단계, 이미지 1/2 Acer Liquid E1 Teardown: 2 단계, 이미지 2/2
    • Use a plastic opening tool or spudger
    • Pry around the side to release the backframe from the middleframe
    • Be careful as the frame is quite fragile
  3. Acer Liquid E1 Teardown: 3 단계, 이미지 1/3 Acer Liquid E1 Teardown: 3 단계, 이미지 2/3 Acer Liquid E1 Teardown: 3 단계, 이미지 3/3
    • To free the main board, remove the connector and antenna-cable
    • Use a plastic spudger
    • Be careful not to chip components
  4. Acer Liquid E1 Teardown: 4 단계, 이미지 1/3 Acer Liquid E1 Teardown: 4 단계, 이미지 2/3 Acer Liquid E1 Teardown: 4 단계, 이미지 3/3
    • Tilting the main board will reveal this connection
    • Use a plastic spudger to open the lock
    • Carefully pull the flex cable out of it
    • Don't put alot of stress on it
  5. Acer Liquid E1 Teardown: 5 단계, 이미지 1/3 Acer Liquid E1 Teardown: 5 단계, 이미지 2/3 Acer Liquid E1 Teardown: 5 단계, 이미지 3/3
    • At the bottom, use a pair of tweezers to remove the yellow tape from the connector
    • Use a plastic spudger to unlock
    • Pull the flexcable out carefully
  6. Acer Liquid E1 Teardown: 6 단계, 이미지 1/2 Acer Liquid E1 Teardown: 6 단계, 이미지 2/2
    • Next, use a platic spudger to remove the flex cable from its connection
  7. Acer Liquid E1 Teardown: 7 단계, 이미지 1/3 Acer Liquid E1 Teardown: 7 단계, 이미지 2/3 Acer Liquid E1 Teardown: 7 단계, 이미지 3/3
    • Use a spudger to remove the bottom-plate from the frame.
    • Be careful when using metal tools (like I did)
    • Make sure the antenna cable isn't attached to anything except it's socket
  8. Acer Liquid E1 Teardown: 8 단계, 이미지 1/3 Acer Liquid E1 Teardown: 8 단계, 이미지 2/3 Acer Liquid E1 Teardown: 8 단계, 이미지 3/3
    • Let the remaining heat at 95°C for about 3-5 minutes to soften the adhesive
    • Use an opening tool to pry at the top, between your digitizer and the middleframe
    • Open it from the top, your digitizer-flex runs at the bottom
    • Be careful when using a heat-gun. Heat-guns don't distribute heat evenly and LCD-burns may occur
  9. Acer Liquid E1 Teardown: 9 단계, 이미지 1/3 Acer Liquid E1 Teardown: 9 단계, 이미지 2/3 Acer Liquid E1 Teardown: 9 단계, 이미지 3/3
    • To remove the LCD, remove the sticker on the back of the midframe. It conseals the LCD-flex
    • Be careful when removing the sticker. It's glued tightly and too much stress will tear the LCD-flex
    • Remove the LCD by pulling the whole cable through the midframe.
  10. Acer Liquid E1 Teardown: 10 단계, 이미지 1/1
    • All done
    • I hope you enjoyed it as much as I did
Maxim
회원 가입일: 04/30/14
2,297 평판
안내서 3개 작성하였습니다
iFixers Belgium iFixers Belgium 회원
Business
1 회원
안내서 5개 작성하였습니다
댓글 한 개
Great Manual.. it work fine! thanks,,
JoeTech - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 16
전체 시간: 6,761
