주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Afterglow Prismatic Wired Controller for Xbox One 수리는 저희 서비스 설명서를 사용하십시오.
  1. Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove clear casing: 1 단계, 이미지 1/2 Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove clear casing: 1 단계, 이미지 2/2
    • Use a Phillips #0 Screwdriver to remove the seven Phillips head screws.
    • Separate two halves of clear casing by holding one side and lifting the other.
  2. Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove main circuit board: 2 단계, 이미지 1/3 Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove main circuit board: 2 단계, 이미지 2/3 Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove main circuit board: 2 단계, 이미지 3/3
    • Lift motors off of controller.
    • Lift circuit board off of controller.
  3. Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove secondary circuit board: 3 단계, 이미지 1/3 Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove secondary circuit board: 3 단계, 이미지 2/3 Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove secondary circuit board: 3 단계, 이미지 3/3
    • Use a Phillips #0 Screwdriver to remove the three screws.
    • Remove triggers by lifting them off the circuit board.
    • Lift the circuit board off of the controller.
  4. Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove power and mute buttons: 4 단계, 이미지 1/3 Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove power and mute buttons: 4 단계, 이미지 2/3 Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove power and mute buttons: 4 단계, 이미지 3/3
    • Remove the power and mute button by pulling them out. They will be loose at this point and may fall out by themselves.
Zachary Crandall
회원 가입일: 01/14/14
151 평판
안내서 1개 작성함
Cal Poly, Team 17-5, Forte Winter 2014 Cal Poly, Team 17-5, Forte Winter 2014 회원
CPSU-FORTE-W14S17G5
5 회원들
안내서 6개 작성하였습니다
댓글 6개
how u clean it because i accident spill tea inside i cleaned it once it worked for a weak and it started to do it again how can i fix it please help me
Xavier Adams - 답글
You should use an earbud/”q-tip” dampened with isopropyl alcohol (otherwise known as IPA) to clean all areas affected by the spill.
infiniti25 -
a phillips #0 doesnt seem to fit into the screws.
reagen_lionel - 답글
How are the poitve and negative leads soldered to the board as I would like to swap wireless internals into controller and keep the lights
glohoodlum - 답글
I am curious about the pair of programmable wheels on the underside, do they have any markings or part numbers on them that would help in sourcing replacements? I’ve been in touch with PDP and confirmed that my controller is past their warranty period, but it is only the underside wheels that have failed and I’m trying to find replacements.
S.R. Cooper - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 18
30일 전: 88
전체 시간: 26,528
