주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Alcatel One Touch Fierce 수리는 저희 서비스 설명서를 사용하십시오.
  1. Alcatel One Touch Fierce Teardown, Alcatel One Touch Fierce Teardown: 1 단계, 이미지 1/3 Alcatel One Touch Fierce Teardown, Alcatel One Touch Fierce Teardown: 1 단계, 이미지 2/3 Alcatel One Touch Fierce Teardown, Alcatel One Touch Fierce Teardown: 1 단계, 이미지 3/3
    • Phillips #000 is highly recommended. As you can see i'm too broke for the iFixIt equivalent.
    • The iSesamo is also always handy.
  2. Alcatel One Touch Fierce Teardown: 2 단계, 이미지 1/2 Alcatel One Touch Fierce Teardown: 2 단계, 이미지 2/2
    • This is the Metro PCS variant of the phone in a nice metallic silver color.
    • The front of this particular device is water damaged and finger print damaged.
  3. Alcatel One Touch Fierce Teardown: 3 단계, 이미지 1/2 Alcatel One Touch Fierce Teardown: 3 단계, 이미지 2/2
    • With the back plastic removed.
    • "DO NOT REMOVE"
    • Challenge accepted
  4. Alcatel One Touch Fierce Teardown: 4 단계, 이미지 1/1
    • The second cover is removed. We now have a better look at the components.
  5. Alcatel One Touch Fierce Teardown: 5 단계, 이미지 1/1
    • The battery. Doesn't last very long.
  6. Alcatel One Touch Fierce Teardown: 6 단계, 이미지 1/2 Alcatel One Touch Fierce Teardown: 6 단계, 이미지 2/2
    • The 5MP camera located on the back of the phone.
  7. Alcatel One Touch Fierce Teardown: 7 단계, 이미지 1/2 Alcatel One Touch Fierce Teardown: 7 단계, 이미지 2/2
    • The daughter board contains the Micro USB port
  8. Alcatel One Touch Fierce Teardown: 8 단계, 이미지 1/2 Alcatel One Touch Fierce Teardown: 8 단계, 이미지 2/2
    • The main PCB
  9. Alcatel One Touch Fierce Teardown: 9 단계, 이미지 1/3 Alcatel One Touch Fierce Teardown: 9 단계, 이미지 2/3 Alcatel One Touch Fierce Teardown: 9 단계, 이미지 3/3
    • The VGA camera located on the front of the phone.
  10. Alcatel One Touch Fierce Teardown: 10 단계, 이미지 1/2 Alcatel One Touch Fierce Teardown: 10 단계, 이미지 2/2
    • The remains of the front panel
  11. Alcatel One Touch Fierce Teardown: 11 단계, 이미지 1/2 Alcatel One Touch Fierce Teardown: 11 단계, 이미지 2/2
    • Trying to remove the front panel assembly.
    • It seemed to have quite a bit of adhesive.
    • Luckily i have a good amount of picks available.
    • Oh no, i think i hear cracking...
  12. Alcatel One Touch Fierce Teardown, Shoot..: 12 단계, 이미지 1/2 Alcatel One Touch Fierce Teardown, Shoot..: 12 단계, 이미지 2/2
    • Crap! i totally saw this coming.
    • To avoid this use a heat gun to loosen the glue...not too much heat though.
  13. Alcatel One Touch Fierce Teardown: 13 단계, 이미지 1/2 Alcatel One Touch Fierce Teardown: 13 단계, 이미지 2/2
    • I now have a functional phone without an LCD screen.
Jonathan Ruiz
회원 가입일: 12/13/11
1,322 평판
안내서 2개 작성하였습니다
댓글 18개
I'm so glad I found this link!!! I broke the screen on my phone two weeks after I bought it, and refused to pay someone $80 to fix it (I didn't pay that much for the phone!). I have NO experience replacing a cell phone screen and this teardown looked pretty straightforward, so I figured it was worth a try. The step by step was easy, worked perfectly, and I can finally see my screen! YAY! Thank you!
Note: Use patience, and it's a breeze!
Barbara Prather - 답글
I also successfully repaired my phone although this guide made it seem like you couldn't do it without ruining the LCD. I'm pretty proficient in phone and electronic repair but I think even beginners could do this one. The new glass that I bought had adhesive already applied to it so I could see exactly where it would be adhered from the factory. I heated the front with a heat gun and started at the top left corner. Once I got a pick in there I started going into the gap with a little X-Acto knife, cutting away at the foam like adhesive. I worked my way down the left side, then went back to the right side, cutting as I went. When only the bottom was attached, I held the phone by the top of the glass and let it dangle. Using the heat gun on the bottom of the glass allowed the weight of the phone to separate itself from the glass. Cleaned it up and put the new glass on, works like new again.
Dan - 답글
I'm about to give this a try Dan. Thanks for your encouragement. Just one question: how did you "clean it up" before putting on the new one? Thanks!!
Janene -
this actually helped! thanks to posted this , my screen broke and ordered it online (ebay) it took a week to get here but man i couldnt see anything with my whole screen cracked! it was cheap as well, 20 bucks with tools! but this really helped!!! just do it calm and slowly , its my first time changing a screen on a phone, this really helped! thanks!
kevin - 답글
I cracked the camera screen on the back a week after buying the phone. Can you tell me where I can get a new one?
thanks!
Shannon - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 62,823
