동영상 개요
- The majority of the device is held together by standard Torx screws.
- The device construction is simple and straightforward to disassemble.
- Antenna cables are soldered to the heat sink and the connectors are hidden behind a plastic frame, The potential for ripping one of these cables is high if you are not careful during disassembly.
- All the ports are soldered to the motherboard.
최종 결론
수리 용이성 점수
7
수리 용이성 10점 중 7점
(10은 가장 쉬운 수리를 뜻합니다)
댓글 3개
So... Where's the teardown?
David Fischer - 답글
i believe something missing with this teardown……
Marlin Rinehart - 답글
8 microphones??!!
Christopher Delaney - 답글
