주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. American Era Electric Rice Cooker 수리는 저희 서비스 설명서를 사용하십시오.
  1. American Era Electric Rice Cooker Teardown, Rice Cooker Teardown: 1 단계, 이미지 1/1
    • Start with the rice cooker unplugged, on a flat surface.
  2. American Era Electric Rice Cooker Teardown, Remove Pot and Lid: 2 단계, 이미지 1/3 American Era Electric Rice Cooker Teardown, Remove Pot and Lid: 2 단계, 이미지 2/3 American Era Electric Rice Cooker Teardown, Remove Pot and Lid: 2 단계, 이미지 3/3
    • Remove the lit and pot and turn upside down.
  3. American Era Electric Rice Cooker Teardown, Remove Bottom Plate: 3 단계, 이미지 1/3 American Era Electric Rice Cooker Teardown, Remove Bottom Plate: 3 단계, 이미지 2/3 American Era Electric Rice Cooker Teardown, Remove Bottom Plate: 3 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove the two screws.
    • Remove the bottom plate by lifting one of the rubber feet.
  4. American Era Electric Rice Cooker Teardown, Remove Internal Screws: 4 단계, 이미지 1/2 American Era Electric Rice Cooker Teardown, Remove Internal Screws: 4 단계, 이미지 2/2
    • We're inside! Here's our first look at the circuitry. Let's take it apart.
    • Use a 3/8" or 8 mm flathead screwdriver to remove these six screws.
  5. American Era Electric Rice Cooker Teardown, Bend Tab: 5 단계, 이미지 1/2 American Era Electric Rice Cooker Teardown, Bend Tab: 5 단계, 이미지 2/2
    • Find the metal tab that connects the center button to the switch lever.
    • Use pliers to bend the metal tab into a U shape.
    • Align the tab with the slot so that it falls through.
  6. American Era Electric Rice Cooker Teardown, Remove Heating Element: 6 단계, 이미지 1/2 American Era Electric Rice Cooker Teardown, Remove Heating Element: 6 단계, 이미지 2/2
    • Turn the rice cooker right-side up.
    • Grab the center button and pull the heating plate upward. The gray metal ring should come out with it.
  7. American Era Electric Rice Cooker Teardown, Remove Temp. Sensor: 7 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to remove the screw connecting the temperature sensor to the heating element.
    • Remove the temperature sensor.
  8. American Era Electric Rice Cooker Teardown, Remove Center Button: 8 단계, 이미지 1/3 American Era Electric Rice Cooker Teardown, Remove Center Button: 8 단계, 이미지 2/3 American Era Electric Rice Cooker Teardown, Remove Center Button: 8 단계, 이미지 3/3
    • Three bent metal tabs connect the center button to the heating element. Use pliers to flatten these three tabs.
    • Remove the center button from the heating element.
  9. American Era Electric Rice Cooker Teardown, Remove Control Panel: 9 단계, 이미지 1/2 American Era Electric Rice Cooker Teardown, Remove Control Panel: 9 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the screw that secures the control panel.
    • Remove the control panel from the outside of the rice cooker.
  10. American Era Electric Rice Cooker Teardown, Disassemble Control Panel: 10 단계, 이미지 1/3 American Era Electric Rice Cooker Teardown, Disassemble Control Panel: 10 단계, 이미지 2/3 American Era Electric Rice Cooker Teardown, Disassemble Control Panel: 10 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove the screw securing the rectangular fiberglass plate. This should free the two light bulbs.
    • Use a Phillips #1 screwdriver to remove two screws securing the switch lever to the control panel plate. Remove the switch lever.
  11. American Era Electric Rice Cooker Teardown, Disassemble Switch: 11 단계, 이미지 1/2 American Era Electric Rice Cooker Teardown, Disassemble Switch: 11 단계, 이미지 2/2
    • Use pliers or hex wrench to hold the nut while using a Phillips #1 screwdriver to remove the screw holding the switch assembly together.
    • Pull the switch assembly apart into its parts. Careful not to lose any of these small parts!
  12. American Era Electric Rice Cooker Teardown, All Done!: 12 단계, 이미지 1/1
    • And here we have it: a fully disassembled rice cooker.
Travis Taylor
회원 가입일: 04/12/13
464 평판
안내서 5개 작성하였습니다
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013 회원
CPSU-AMIDO-S13S10G40
4 회원들
안내서 37개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 7
30일 전: 45
전체 시간: 4,063
