주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Apple Studio Display M2454 수리는 저희 서비스 설명서를 사용하십시오.
  1. Apple Studio Display M2454 Teardown, Apple Studio Display M2454 Teardown: 1 단계, 이미지 1/1
    • Notice that the main components of the monitor are only accessible from the back of the device.
  2. Apple Studio Display M2454 Teardown: 2 단계, 이미지 1/1
    • Locate the four hex head screws located on the corners of the back panel.
    • Remove the screws with a 2mm hex screwdriver.
  3. Apple Studio Display M2454 Teardown: 3 단계, 이미지 1/1
    • Remove the clear and gray back panels.
  4. Apple Studio Display M2454 Teardown: 4 단계, 이미지 1/1
    • Remove the three screws with #2 phillips head screwdriver.
  5. Apple Studio Display M2454 Teardown: 5 단계, 이미지 1/1
    • To remove the metal panel, push towards the bottom of the monitor to release its clips and pull the panel away.
  6. Apple Studio Display M2454 Teardown: 6 단계, 이미지 1/1
    • Remove screw holding the plastic bracket with #2 Phillips head screwdriver.
  7. Apple Studio Display M2454 Teardown: 7 단계, 이미지 1/1
    • Remove the four screws on the metal bracket.
  8. Apple Studio Display M2454 Teardown: 8 단계, 이미지 1/1
    • Remove the two philips head hold-down screws with the #2 Phillips head screwdriver.
  9. Apple Studio Display M2454 Teardown: 9 단계, 이미지 1/1
    • Remove black connector by pushing the end of the tab closest to the wiring and pulling away from board.
  10. Apple Studio Display M2454 Teardown: 10 단계, 이미지 1/1
    • Remove white connector by lifting tab and pulling away from board.
    • Be careful when lifting tabs, they break easily.
  11. Apple Studio Display M2454 Teardown: 11 단계, 이미지 1/1
    • Remove connector connected to the hold down previously removed simply by pulling with hand.
  12. Apple Studio Display M2454 Teardown: 12 단계, 이미지 1/1
    • Now that the main computer cable is detached, remove it away from monitor.
  13. Apple Studio Display M2454 Teardown: 13 단계, 이미지 1/1
    • Remove the two screws holding the USB port in place with #2 Phillip's head screwdriver.
  14. Apple Studio Display M2454 Teardown: 14 단계, 이미지 1/1
    • Remove the screw on the wire hold down with #2 Phillips head screwdriver.
  15. Apple Studio Display M2454 Teardown: 15 단계, 이미지 1/1
    • Remove white connector connected to LCD main board by lifting tab with tool and pulling away from board.
  16. Apple Studio Display M2454 Teardown: 16 단계, 이미지 1/1
    • The USB port is now detached, remove it from monitor.
  17. Apple Studio Display M2454 Teardown: 17 단계, 이미지 1/1
    • Remove connector on the left bottom corner of the LCD main board by simply pulling with hand.
  18. Apple Studio Display M2454 Teardown: 18 단계, 이미지 1/1
    • Remove the connector on the bottom right corner by 1st removing tape first and pulling with hand.
  19. Apple Studio Display M2454 Teardown: 19 단계, 이미지 1/1
    • Remove top right connector of the LCD main board by pulling with hand.
  20. Apple Studio Display M2454 Teardown: 20 단계, 이미지 1/1
    • Remove the final connector of the LCD main board by pulling with hand.
  21. Apple Studio Display M2454 Teardown: 21 단계, 이미지 1/1
    • Remove the four screws on each corner of the main board with #2 Phillips head screwdriver.
  22. Apple Studio Display M2454 Teardown: 22 단계, 이미지 1/1
    • The board is now detached, remove it from monitor.
  23. Apple Studio Display M2454 Teardown: 23 단계, 이미지 1/1
    • Locate the top and bottom connector on the CCFL inverter and remove it by inserting pin into the small holes and pulling away.
    • This step may be easier with two people.
  24. Apple Studio Display M2454 Teardown: 24 단계, 이미지 1/1
    • Remove the two screws on the top and bottom of the CCFL inverter with #2 Phillips head screwdriver.
  25. Apple Studio Display M2454 Teardown: 25 단계, 이미지 1/1
    • The CCFL inverter is now detached, remove it from monitor.
  26. Apple Studio Display M2454 Teardown: 26 단계, 이미지 1/1
    • You have now successfully taken apart a Apple Studio Display M2454.
Dylan Perry
회원 가입일: 01/20/10
177 평판
안내서 5개 작성하였습니다
Cal Poly, Team 13-27, Maness Winter 2010 Cal Poly, Team 13-27, Maness Winter 2010 회원
CPSU-MANESS-W10S13G27
4 회원들
안내서 9개 작성하였습니다
댓글 3개
This model is also known as the Apple Studio Display 15" LCD.
analogcd - 답글
excellent wee guide......i came here in my search for a replacement stand for this model.
bobby nailen - 답글
Failing caps were the main problem with this — no air flow.
Mal - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 25
전체 시간: 7,587
