주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Apple TV 3rd Generation 수리는 저희 서비스 설명서를 사용하십시오.
  1. Apple TV 3rd Generation Teardown, Apple TV 3rd Generation Teardown: 1 단계, 이미지 1/2 Apple TV 3rd Generation Teardown, Apple TV 3rd Generation Teardown: 1 단계, 이미지 2/2
    • Less than four inches square and an inch tall (the exact size of the 2nd generation Apple TV) the small but mighty Apple TV 3rd Generation adds the ability to play 1080p HD content.
    • The backside of the Apple TV 3rd Generation features the same exact ports as the previous iteration:
    • AC adapter port
    • HDMI output port
    • Micro-USB (for service and support)
    • Optical audio out port
    • 10/100 Base ethernet port
  2. Apple TV 3rd Generation Teardown: 2 단계, 이미지 1/3 Apple TV 3rd Generation Teardown: 2 단계, 이미지 2/3 Apple TV 3rd Generation Teardown: 2 단계, 이미지 3/3
    • With little effort from our part, we dive right into the Apple TV by removing the snap-on base.
    • Once inside, we notice an immediate difference from the Apple TV 2nd Generation, the lack of a thermal pad.
    • Perhaps the "new" A5 processor doesn't get as hot?
  3. Apple TV 3rd Generation Teardown: 3 단계, 이미지 1/2 Apple TV 3rd Generation Teardown: 3 단계, 이미지 2/2
    • A quick turn of our screwdriver frees the metal heat sink.
    • Under the metal heat sink resides a small thermal plate, just like in the previous generation.
    My Apple TV didn’t have this heat sink in it. It does have the screws where the heat sink would go.
    kc7gnm77 - 답글
  4. Apple TV 3rd Generation Teardown: 4 단계, 이미지 1/2 Apple TV 3rd Generation Teardown: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Spudger
    $3.99
    구매
    • The logic board is held in place by the power supply connector, but that's no problem for our spudger. A quick flick and the logic board is free.
    • So far, this device has been significantly easier to crack open than last week's iPad 3. We have a feeling the trend will continue with the Apple TV, since we just took out almost everything inside.
  5. Apple TV 3rd Generation Teardown: 5 단계, 이미지 1/2 Apple TV 3rd Generation Teardown: 5 단계, 이미지 2/2
    • Clearing this casing is fast and easy. The power supply is one of the few parts left.
    • The rating of the power supply is 3.4V at 1.75A, which is identical to the 2nd Gen Apple TV's 5.95 watts.
    • If it ain't broke, why fix it?
  6. Apple TV 3rd Generation Teardown: 6 단계, 이미지 1/2 Apple TV 3rd Generation Teardown: 6 단계, 이미지 2/2
    • The last remaining part in the Apple TV is the status LED.
    Is this the IR receiver as well? I want to put this board in a DIY Speaker system I'm building. Should be amazing.
    Erick Smith - 답글
    The IR receiver is the little LED looking thing in step 8, about halfway between the orange Apple 343S0479 chip and the end of the board.
    Louis Moga -
  7. Apple TV 3rd Generation Teardown: 7 단계, 이미지 1/1
    • Logic board is disassembled next, but first a quick message from our favorite sponsor, us:
    • We also make software for teaching people to do things. Dozuki makes it easy to create vibrant how-to manuals.
    • Dozuki is great for:
    • Standardized work instructions: improve quality by documenting how to get things done, one step at a time.
    • Building product support sites: make your customers love you by teaching them how to do amazing things.
    • Training and e-learning software: we've used Dozuki to teach over ten million people to repair electronics.
    • Online community platform: build a knowledge base of expert knowledge with Answers, the Q&A engine that drives the popular iFixit Answers.
    • Lots more: Dozuki shines in any situation where you need to harness the knowledge of experts to teach people to do things in the real world.
  8. Apple TV 3rd Generation Teardown: 8 단계, 이미지 1/3 Apple TV 3rd Generation Teardown: 8 단계, 이미지 2/3 Apple TV 3rd Generation Teardown: 8 단계, 이미지 3/3
    • The bottom side of the logic board:
    • Apple A5 Single Core processor
    • The A5 PoP assembly breaks down into a Hynix LP DDR2 SDRAM and an application processor that carries the part number APL2498 and 8942C01 (third image). Thanks Chipworks!
    • Toshiba THGVX1G6D2HLA01 8GB NAND Flash
    • Broadcomm BCM4330 (appears to be the same chip in the iPad 3rd Generation).
    • Apple 343S0479
    • Apple 338S1040
    There is no reference regarding N438HB1 on Chipworks site! Any help?
    Dimitar - 답글
    Apple 343S0479 and Apple 338S1040 are swapped out accidentally on the first photo. The colors are wrong.
    You can see in the second photo that the yellow outlined chip is actually the Apple 343S0479 which is for HDMI (hence its proximity to the hdmi port and when closely looked at the traces it being connected to the ports filters).
    The Apple 338S1040 is supposedly an audio and power management ic.
    Instant Muffin - 답글
  9. Apple TV 3rd Generation Teardown: 9 단계, 이미지 1/1
    The 30 pin connector should work if you add in the passive protection components (under the RF shielding)...
    Slot1gamer - 답글
  10. Apple TV 3rd Generation Teardown: 10 단계, 이미지 1/1
    • Looking closely it appears that there is another difference from the Apple TV 2nd Generation, two antennas!
    • While it is unclear where the two antennas terminate, we suspect Apple added the second antenna to address some complaints about range and signal strength in the previous model.
    • According to Broadcom, the BCM4330 can either function with a single-band 2.4 GHz 802.11 b/g/n (single shared 2.4 GHz antenna for Bluetooth and WLAN) or a dual-band 2.4 GHz and 5GHz 802.11 a/b/g/n antenna.
    • We're suspecting that this Apple TV is preserving the 2.4GHz shared antenna, but has also added a second antenna for 5 GHz connectivity.
    I'll note that my 1080p Apple TV can see both my 2.4 GHz and 5 GHz WiFi networks, whereas my old 720p Apple TV can only see the 2.4 GHz network.
    David Krug - 답글
    Are the antennas the ones on the corner? What do you think…if I physically disable antennas, could my ATV still streaming via Ethernet connection?
    Ger man - 답글
  11. Apple TV 3rd Generation Teardown: 11 단계, 이미지 1/2 Apple TV 3rd Generation Teardown: 11 단계, 이미지 2/2
    • Apple TV (3rd Generation) Repairability: 8 out of 10 (10 is easiest to repair).
    • Only six parts in a very easy-to-dissemble case.
    • Separate power supply, which is easy to get to and replace in case your old one ever decides to jump off a cliff.
    • No glue, thermal paste, gum, peanut butter holding things in place...
    • Standard screws, no endangered species screwdrivers necessary.
    • The logic board contains all the components, which means if something breaks, it could be expensive to replace -- unless you prefer to do board-level soldering.
댓글 7개
Noticed on a new Apple TV the Phillips screws have been replaced by Torx and the bottom plate has been changed, The recess for the led connector is now open and not a complete rectangle
simon donovan - 답글
So I decided to teardown my 3rd Gen Apple TV just out of curiosity, and when I managed to finally open it, my unit is missing a Heat Sink, all that is there is the silver thermal plate. Is this a bad thing or does it not matter much? Maybe it was an error in the manufacturing process.
Lian Silveira - 답글
Do you know how to fix problems with electricity connection?
Fernando - 답글
Hey guys
Thank you so much for helping all of us out.
My Apple TV is having static problems seems to me it’s a problem with the HDMI port as I have tried over 15 different hdmi cables.
If there is a fix for that can you please help me out.
Thanks again you guys are doing a fantastic job!
Hardy
Hardy Rayat - 답글
Hello, I am doing a USB power mod to my AppleTV Gen3 A1469. All I will need is the HDMI connector. I have minor soldering skills. Is it easy to desolder all the other connectors? I plan on fashioning out a wafer-thin case out of polystyrene plastic.
Mario Choy - 답글
Just some extra information: While disassembling the A1469 (newer revision of apple tv gen 3) I think I identified the IR reciever to be the TSOP77338TT, made by Vishay.
qwertyuiop - 답글
is there a way to make apps downloadable on this version?
david - 답글
댓글 쓰기
조회 통계:
24 시간 전: 12
7일 전: 61
30일 전: 241
전체 시간: 195,129
