해당 분해도에 사용된 도구
소개
A simple look into the Universal Dock
Need a flat nose screw driver 2.4mm
philip screw driver #1
해당 분해도는 수리 안내서가 아닙니다. Apple Universal Dock Model A1256 수리는 저희 서비스 설명서를 사용하십시오.
  1. Pry along the edge of the bottom of the case. It will just pop out.
    • Pry along the edge of the bottom of the case. It will just pop out.
  2. Remove the top case from the bottom.
    • Remove the top case from the bottom.
  3. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. There are five Phillips screws holding the metal brace down (In the picture I have already removed them).
    • There are five Phillips screws holding the metal brace down (In the picture I have already removed them).
  5. The brace is glued in near the ir-sensor. You may have to apply a little bit force to remove it, but it will come out with just pulling. (You can pry it a little bit with a spudger or a screwdriver) The brace is glued in near the ir-sensor. You may have to apply a little bit force to remove it, but it will come out with just pulling. (You can pry it a little bit with a spudger or a screwdriver)
    • The brace is glued in near the ir-sensor. You may have to apply a little bit force to remove it, but it will come out with just pulling. (You can pry it a little bit with a spudger or a screwdriver)
  6. The only major chip located on the circuit board. (All those who have wondered about the dock's line out, I think we are clear now.) The only major chip located on the circuit board. (All those who have wondered about the dock's line out, I think we are clear now.)
    • The only major chip located on the circuit board. (All those who have wondered about the dock's line out, I think we are clear now.)
Devilac
회원 가입일: 2010년 06월 23일
67 평판
안내서 1개 작성함
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 27
전체 시간: 22,289
