주요 콘텐츠로 건너뛰기
해당 분해도는 작업 중 입니다 – 최신 변경 사항을 보려면 주기적으로 다시 로드 하십시오!
필요한 것
동영상 개요
  1. Asus ZenBook 13 UX331U Teardown, Asus ZenBook 13 UX331U Teardown: 1 단계, 이미지 1/3 Asus ZenBook 13 UX331U Teardown, Asus ZenBook 13 UX331U Teardown: 1 단계, 이미지 2/3 Asus ZenBook 13 UX331U Teardown, Asus ZenBook 13 UX331U Teardown: 1 단계, 이미지 3/3
    • The back panel is removed.
    • The SSD is removed.
IT FIX
회원 가입일: 10/16/17
6,340 평판
안내서 74개 작성하였습니다
댓글 12개
Bonjour,
Je n' arrive pas a voir le disque dur de l' ordinateur. Est il accessible?
Peut il être changé ?
schauch - 답글
You mean that you pc can’t see the hard drive? Even in bios?
IT FIX - 답글
Boni can't see it on the video. I d like to buy one of these laptop and change the hard drive for a bigger one. Is it easy to do it?
schauch - 답글
It’s very easy but it’s supports only M.2 SSDs
IT FIX - 답글
Hi there,
I own this laptop, and the internal fan has started to make rattling-like noises, as well as suddenly stopping and starting after a period of watching videos and the like. I am wondering if this is due to dust clogging the CPU fan, and whether compressed air can be used to clean up. If it’s not due to dust clog, what else might be the problem?
Thanks.
Sai - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 23
전체 시간: 6,432
