필요한 것
댓글 20개
I'm excited to find out if the middle button is actually a digital crown and whether or not there is NFC. This was built for wear 2.0 after all.
Is it possible to also see a picture of the chip side of the PCB? Would like to see how the 2100 is designed into the board
What should I do if the power button doesn’t work?
I took mine apart for this very thing. The other buttons clearly click, but the middle button was kind of mushy. I don’t see a way to easily remove the button from the circuit board. However, in looking it over, I found that if the circuit board is pressed firmly while pressing the power button, it does get the thing to click. Upon reassembly, I found this to still be true. When the power button doesn’t work, if I squeeze the watch, face to back, and at the same time press the button, it makes contact.
