주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Asus ZenWatch 3 수리는 저희 서비스 설명서를 사용하십시오.
  1. Asus ZenWatch 3 Teardown, Let's begin: 1 단계, 이미지 1/1
    • Tools needed T5 screwdriver
  2. Asus ZenWatch 3 Teardown, Band Removal: 2 단계, 이미지 1/2 Asus ZenWatch 3 Teardown, Band Removal: 2 단계, 이미지 2/2
    • Remove pins securing the band
  3. Asus ZenWatch 3 Teardown, Open the body: 3 단계, 이미지 1/1
    • Remove the four screws
  4. Asus ZenWatch 3 Teardown: 4 단계, 이미지 1/1
    • Pry open at the side near the rose gold ring
  5. Asus ZenWatch 3 Teardown: 5 단계, 이미지 1/1
    • The battery would be automatically disconnected
  6. Asus ZenWatch 3 Teardown: 6 단계, 이미지 1/1
    • Battery
  7. Asus ZenWatch 3 Teardown: 7 단계, 이미지 1/1
    • Remove ribbons connected to the board
  8. Asus ZenWatch 3 Teardown: 8 단계, 이미지 1/1
    • Complete disassembly
Reon
회원 가입일: 02/01/13
141 평판
안내서 1개 작성함
댓글 20개
I'm excited to find out if the middle button is actually a digital crown and whether or not there is NFC. This was built for wear 2.0 after all.
Joseph White - 답글
Is it possible to also see a picture of the chip side of the PCB? Would like to see how the 2100 is designed into the board
Jan Gaudestad - 답글
Does anybody know how the third button can be replaced? I lost it. Thank you in advance for any help.
splatdom - 답글
What should I do if the power button doesn’t work?
MichaelKing10or - 답글
I took mine apart for this very thing. The other buttons clearly click, but the middle button was kind of mushy. I don’t see a way to easily remove the button from the circuit board. However, in looking it over, I found that if the circuit board is pressed firmly while pressing the power button, it does get the thing to click. Upon reassembly, I found this to still be true. When the power button doesn’t work, if I squeeze the watch, face to back, and at the same time press the button, it makes contact.
Brodie Krause -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 62
전체 시간: 14,586
