소개
This guide is limited to steps without soldering required, giving you access to auxiliary input, speakers, and internal wiring. The upper, over head, assembly will require a separate guide.
필요한 것
Unfold the headphones face up for easy access to the Foam Earpads.
Insert index finger underneath foam, pinch foam between thumb and index and slowly ease the compression fitting out of its track.
Repeat same process for right Earpad.
Remove four J1 screws.
Carefully lift plate to avoid putting any strain on the internal wiring. Note that connections are soldered.
Make sure to free the speaker wire from W shaped spring before setting the Speaker plate next to the headphone assembly.
Unscrew the three remaining J1 screws.
Lift speaker retainer away from speaker.
The speaker now comes away easily from the speaker plate.
