주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Audio-Technica ATH-M50x 수리는 저희 서비스 설명서를 사용하십시오.
  1. Audio-Technica ATH-M50x Teardown, Remove Foam Earpads: 1 단계, 이미지 1/3 Audio-Technica ATH-M50x Teardown, Remove Foam Earpads: 1 단계, 이미지 2/3 Audio-Technica ATH-M50x Teardown, Remove Foam Earpads: 1 단계, 이미지 3/3
    • Unfold the headphones face up for easy access to the Foam Earpads.
    • Insert index finger underneath foam, pinch foam between thumb and index and slowly ease the compression fitting out of its track.
    • Repeat same process for right Earpad.
  2. Audio-Technica ATH-M50x Teardown, Remove Speaker Plate: 2 단계, 이미지 1/3 Audio-Technica ATH-M50x Teardown, Remove Speaker Plate: 2 단계, 이미지 2/3 Audio-Technica ATH-M50x Teardown, Remove Speaker Plate: 2 단계, 이미지 3/3
    • Remove four J1 screws.
    • Carefully lift plate to avoid putting any strain on the internal wiring. Note that connections are soldered.
    • Make sure to free the speaker wire from W shaped spring before setting the Speaker plate next to the headphone assembly.
  3. Audio-Technica ATH-M50x Teardown, Remove Speaker Housing and Speaker: 3 단계, 이미지 1/3 Audio-Technica ATH-M50x Teardown, Remove Speaker Housing and Speaker: 3 단계, 이미지 2/3 Audio-Technica ATH-M50x Teardown, Remove Speaker Housing and Speaker: 3 단계, 이미지 3/3
    • Unscrew the three remaining J1 screws.
    • Lift speaker retainer away from speaker.
    • The speaker now comes away easily from the speaker plate.
  4. Audio-Technica ATH-M50x Teardown, Repeat steps 2 and 3 for Left Earpiece: 4 단계, 이미지 1/1
    • To remove speakers will require soldering skill.
Broske
회원 가입일: 07/20/20
181 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 13
30일 전: 42
전체 시간: 8,348
